Home > Technical (L322) > Air Spring Exploded! |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Based on my experience with an 06 L322 I would answer as follows:
23rd Sep 2018 12:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Only seen a report of one other airbag seriously letting go, this was reported on here a few years ago and was a left hand rear bag. It let go when on the move, but the owner was able to safely pull onto the hard shoulder and stop. Control in this situation possibly easier if the rear one goes.
23rd Sep 2018 1:20pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Scary thought but I'm glad it burst whilst parked sir...
23rd Sep 2018 5:10pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I changed my front strut assemblies at 10 year mark, as anacdotally seems to be increased reports of failure after this time.
23rd Sep 2018 8:26pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
On our old L322 (2002) I had the front left airbag go when I hit a pothole at about 30 mph - it just exploded and the corner dropped to the bump stop instantly. There was no pull on the steering or any loss of control - the corner just dropped. It was drivable enough to get it the 10 miles home (albeit rather slowly).
23rd Sep 2018 9:57pm |
phn Member Since: 10 Aug 2018 Location: Norwich Posts: 27 |
Thanks for all the replies - makes sense - will get the opposite front air shock fitted as soon as possible.
24th Sep 2018 6:49am |
Don't think it will make any difference TBH. Pressure is probably the same anyway as it still needs to support weight of the FF regardless of height setting.
24th Sep 2018 5:27pm |
The lower you leave it, the less you scuff/wear your seat edges
24th Sep 2018 8:43pm |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
My drivers side front went a loud bang while I was parked .
26th Sep 2018 5:51pm |
Yes, the garage had a difficult job with the bolts on mine which were sacrificed in the end, and new bolts put in along with the new strut!
28th Sep 2018 8:25pm |
