Home > Maintenance & Mods (L322) > Fitting towbar to a design pack FF
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Fitted a Westfalia to my last FF so familiar with the process, but looking at a potential replacement that has a design pack (different rear bumper with integrated exhaust tips etc) and no towbar Rolling Eyes
So, is it a lot more faff to fit a towbar to a design pack car?
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #489699 23rd Sep 2018 3:52pm
Not at all... The under tray has a line to cut to for it to fit around the tow bar... So very easy sir Thumbs Up
Post #489702 23rd Sep 2018 4:01pm
mm289
Cool, thanks CTC, so basically just same process as on my 06 but relieve the undertray to the cut out markings?
Cheers,
Paul. 2011 TDV8 AB
Post #489706 23rd Sep 2018 4:22pm
Yep thats correct sir... They even have a recess built into the bumper where the factory electrics appear as if you fitted them that way! (all will be come clear if you look at a bumper fitted) Thumbs Up
Post #489710 23rd Sep 2018 4:30pm
mm289
Cheers bud Thumbs Up 2011 TDV8 AB
Post #489713 23rd Sep 2018 4:48pm
Post #489716 23rd Sep 2018 4:50pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Mine had one on before Craig took it off Crying or Very sad will get a few pics Thumbs Up there's a large tray my electrics sit in under the back.
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #489822 24th Sep 2018 12:37pm
mm289
Great thanks Thumbs Up
Paul. 2011 TDV8 AB
Post #489852 24th Sep 2018 5:25pm
mm289
Went straight of on hols after picking the car up so just had my first chance to look at the towbar.
Fitting all looks very neat but can't see how to access the electrics Question
Probably missing something silly, but do you have to remove the black panel under the bumper or does that cut out section in the rear bumper open?
Scott trying to work out how you access that tray you talk about - I can see the 13 pin up inside the bumper but can't figure out how to get to it Whistle
Cheers,
Paul. 2011 TDV8 AB
Post #492329 14th Oct 2018 8:15pm
mm289
Any suggestions? Wink
cheers Thumbs Up
paul 2011 TDV8 AB
Post #492692 17th Oct 2018 6:39pm
