![]() | Home > Maintenance & Mods (L322) > painting rear exhaust 'box' |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
done the exhaust and anything else i could under the back of the range ..used wickes 'direct to metal' paint ......... ... - .- -.
I dont think the rear box gets all that hot. So you should be OK with most paints I guess. |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
thanks guys - not as mad as i thought - |
I have painted loads with any heat resistant mat or satin black paint. Even Barbeque Spray paint is effective as its totally heat resistant.
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
I can't stand sight of mine, so thinking about dumping and replacing with custom twin pipes like the supercharger exhaust. Nothing larey, just oem style. Seen Midlands exhaust do set up on ebay for 260 so going to look local for similar set up.
Not my cup of tea - I think the fact you cant see the pips on the RR is classy. ![]() |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Satin black high temp paint has worked a treat on mine, just give it a quick once over every few months to keep it looking tidy |
But on the supercharger you can just see tips which is classy and cool. I just want a S/C exhaust on my 4.4 really. Do they fit??
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Did mine with matt black exhaust paint from my local autofactors.
i think all exhaust show the 'silvery metal' bit after a while and it is so easy to put the RR into high mode and walk |
i used satern black paint, the box does not get hot at all, just give a going over with wire wool and your ready to go...looks the part when done, when i am ever behind a rr i always look at there back box...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1976 Harley Davidson Iron Head Sportster |
That looks superb! Did you remove the box to paint or leave in situ. What pipes have you added and where from at what cost if you don't mind me asking!!
Any more pics from the side maybe? |
http://www.fullfatrr.com/forum/topic2333.h...arge+trims V8 facelift Range Rover Autobiography 22" wheels.
