Home > Maintenance & Mods (L322) > Tdv8 3.6 oil - full or semi synthetic?
rar110
Which do people use/recommend?
The Penrite guide tells me either is ok.
I’m in a subtropical environment if that’s relevant, and so use 5w40.
Thanks. ______________________________
Post #489524 22nd Sep 2018 2:37am
Weegie
I only ever use fully synthetic. Did the same with the D2 and the td6. The D2 was 5w40. John
GAP iiD BT
Post #489527 22nd Sep 2018 6:05am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Hey rar110
I’m using Nulon SYNFE 5w30
Meets the Ford oil spec (which I don’t recall at the moment)
Order it in at repco and buy when they have the sales on.
I found Penrite too confusing 2007 3.6 TDV8
Post #489549 22nd Sep 2018 10:49am
rar110
Ta Steve
The tdv8!Oil spec is:
MCC913 B, WSS-M2C 934-B, 921-A
Both Penrite oils comply with this.
Is this the Nulon Oil you use?
https://www.nulon.com.au/products/full-syn...lsrc=aw.ds ______________________________
Post #489553 22nd Sep 2018 11:36am
cheezels
https://www.nulon.com.au/products/full-syn...engine-oil
I've been using it a couple of years now.
Tried Penrite (got annoyed with having to buy two 6 litre jugs) and at one stage Castrol (which was silly expensive). The Nulon was cheaper than everything else (at the time I was buying), so I thought I'd give it a go, as it met the oil spec'.
With fear of starting poo storm, so long as it meets the spec' in the owners manual "she'll be right".
Having said that, I do use MOS2 additive package from Liqui Moly with new oil and use Liqui Moly Detox when changing oil.
I don't lay claim to any conclusive engine longevity, but in my experience, the engine is benefitting. 2007 3.6 TDV8
Post #489556 22nd Sep 2018 12:33pm
rar110
Ta Steve ______________________________
Post #489629 23rd Sep 2018 1:21am
rar110
gday Cheezels
LiquiMoly products were on special at SCA last weekend so I bought some diesel purge, oil flush and some MOS2 oil additive.
Ive used the Cost Effective Maintenance oil additive, but thought I would give the MOS2 a try also. Im doing a NT trip in June so some additional/different protection could be useful, particularly if an oil starved turbo situation arises. I use the CEM oil flush product, but will probably do an oil flush with the LiquiMoly product and an oil change before I leave.
Im also looking to use the diesel purge product, just need some more info on this first. ______________________________
Post #510396 31st Mar 2019 11:48am
cheezels
Lol. I bought some during the sale as well.
Just done an oil flush with CEM this time and drained from both sump plugs.
The oil was very black, but the MOS2 is probably causing some of the discolouration.
I’m now using Fuch oil as I’m over Penrite confusion and Nulon availability is a bit hit and miss.
I can’t say for sure if flushing and adding MOS2 will help with longevity but I’m confident it’s not hurting anything, and the engine does feel a bit “perkier”
Haven’t used the liqui moly diesel flush, but still using CEM additive.
NT trip sounds great! 2007 3.6 TDV8
Post #510469 31st Mar 2019 11:42pm
rar110
The CEM engine flush is good. The new oil stayed cleaner longer. I’m not sure about the CEM additive.
I should drop in one day as I have oversupply of CEM fuel treatment. Maybe on way to NT. ______________________________
Post #510480 1st Apr 2019 8:21am
j_rov
https://topix.landrover.jlrext.com/topix/s...amp;page=1 __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #510483 1st Apr 2019 9:12am
cheezels
That would be great to see you!
The CEM fuel additive does improve my “gas mileage”. Interestingly, I suggested my mate tried it as he was having issues with a couple of injectors in his Landcruiser. It has actually brought the injector balance back in line. 2007 3.6 TDV8
Post #510489 1st Apr 2019 9:32am
rar110
I bought the diesel pack. It came with a heap of FTC Decarboniser. ______________________________
Post #510493 1st Apr 2019 10:04am
rar110
And thanks J_rov for the topix link. ______________________________
Post #510494 1st Apr 2019 10:08am
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
Fully synth from Opie oils, good price, speedy delivery and forum discount.
Post #510544 1st Apr 2019 5:34pm
