![]() | Home > Technical (L322) > Air suspension worries |
Careful while you are away from home with all that resetting, you may find yourself down on the bumpstops a long way from home! Best left alone, especially if it is running at normal height. Just leave it until you can diagnose whether you have a height sensor problem or a leak airbag / pipe somewhere .
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Have you had to change the bags yet?
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I think the important one there is:
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 ![]() ![]() ![]() |
I have changed the bags earlier this year and also near side front sensor the near side bag also seems to be more defalted than the others and I heard air leaking from the bag but it hat could off been the system going into limp mode |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Don't suppose your tracking is out is it - the 45mph thing is similar to something I had in mine a while ago when some of the rear suspension bushes were changed and it needed realigned - the Air Supension used to lock out around 40-45mph but happily reset again. Could be completely wrong, but if your steering wheel is slightly off centre this can cause issues. Current Fleet:-
Sorry for the late reply yes the steering wheel is slightly off but I found that the nearside air bag is defective which I have brought another one just finding the time to fit once done it will go down to kwick fit for wheel alignment 👍 |
