Home > Technical (L322) > Droning noise at exactly 1000 revs !
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
For the last 4 months I have been getting a droning noise when the engine is at 1000 Revs regardless of acceleration or deceleration. It sounds like a light aircraft is near you. It is very noticable when driving at low speeds and especially in a car park which is covered...Any ideas folks..?
It has been at the dealers but they can't find anything at the moment so it is rebooked in...the issue occured as soon as I got the car back from the Dealers following a Turbo drain mod so maybe something to do with that.. ?
Thanks I need more help than most...sorry !!
Post #488645 11th Sep 2018 9:35am
Baltic Blue
Does this sound familiar Stan ?
Did you ever resolve your vibrations?
Post #488646 11th Sep 2018 9:40am
it does sound familiar Mike..
muppet, take it back and ask them to double check the nuts and bolts and maybe realign the cross member they had to drop when doing the turbo drain mod...
...and mine is fine now.. Thumbs Up
Post #488647 11th Sep 2018 9:44am
muppet
will do, Thanks...was yours the same IE at 1000 revs ? I need more help than most...sorry !!
Post #488650 11th Sep 2018 10:04am
more on idle and when i revved it to around 1000rpm it started to disappear.
Post #488651 11th Sep 2018 10:07am
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Check your engine mounts as if like the SDV6 in the Discovery they are vacuum operated. A pipe can easily be knocked off. Thumbs Up
Post #488654 11th Sep 2018 10:30am
qwerty
Did you get this sorted?
Post #495244 11th Nov 2018 6:46pm
muppet
its booked into the dealers for Monday next week, they take months to get you a slot.. I need more help than most...sorry !!
Post #495275 12th Nov 2018 8:25am
muppet
issue resolved, loose under car protection tray, all tightened up and seems ok... I need more help than most...sorry !!
Post #497045 29th Nov 2018 6:35pm
