Home > Technical (L322) > fault after pixel repair
nicam
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
After a couple of years of guessing at the messages being displayed I sent the instrument pod off to have the pixel display fixed. I have just refitted the display and the pixel display is perfect.
BUT there are many problems elsewhere that were not there before. HELP!
There is no instrument illumination. there are no warning lights, indicator lights or gear indicator lights. The tacho works - don`t know about the speedo as I didn`t move the car.
The pixel display reads "air suspension inactive" , alternating with "Stop Engine - oil pressure failure". but it hasn`t
The handbrake warning light is on all the time - the ABS light is on very faintly! but that is all you can see on the dash.
The outside lights all work OK and the indicators work OK - just not the dash.
Non of this was a problem before the dash coming out and then back in!
My firstt hought is to return the dash to the guy who fixed it, but I would hope he tested it before returning AND I would expect the messages to be coming from the ecu, not be generated in the dash unit.
Any ideas please?
Nicam Don`t drive faster than your Angel can fly.
Post #488102 5th Sep 2018 9:43pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Have you try`d unplugging the multi plugs and plugging them back in it might just a bit of a bad connection.
Post #488108 5th Sep 2018 10:52pm
nicam
Yes they have been on and off a couple of times. Still the same. All the connector pins look ok as well - none are bent or damaged. Don`t drive faster than your Angel can fly.
Post #488111 6th Sep 2018 7:04am
nicam
But, just to check I took them all out again and refitted them - just the same.
Then, as I was pulling the pod out to remove them again the indicator lights flashed.
I had pressed the hazard light switch by accident and moving the instrument pod must have disturbed a connector.
A quick check revealed a dodgy connection on the black socket/plug so a removal and refit several times has it sorted.
Thank you kds2 for making me check the connectors again.
Result. Don`t drive faster than your Angel can fly.
Post #488112 6th Sep 2018 8:08am
kds2
Glad to see you are sorted. Very Happy
Post #488224 7th Sep 2018 12:07am
