Home > Technical (L322) > Torque Converter Test??
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Afternoon All does anyone know if it’s possible to ‘test’ my TC using live values from the GAP tool?
I’ve the fluctuating revs and occasional ‘cattle grid’ vibration when accelerating
Don’t want to replace it and find out the problems are still there!
Post #487835 2nd Sep 2018 2:53pm
Mikey
Not really. It’s a mechanical issue, as opposed to a an electrical one. Hugely common in the 6HP boxes, caused by a worn torque converter
Providing you have not left the issues too long, you will get away with a replacement TC and fresh oil and filter Thumbs Up
Post #487840 2nd Sep 2018 3:48pm
RRPhil
You can use the IIDTool to monitor and record the engine speed, turbine speed and EDS6 current simultaneously, at a reasonable capture rate, which - when plotted out - shows exactly what the lock-up clutch is up to
http://www.fullfatrr.com/forum/post482668.html#482668
Phil
Post #487842 2nd Sep 2018 4:16pm
Andyyav
Thanks Phil excellent info Bow down I’ll read the manual for the GAP tool and see what I can do, just spoken to the local LR independent garage who have quoted £3300 as they suggest replacing the gearbox at the same time as the TC......thoughts please
Post #487878 3rd Sep 2018 10:39am
RRPhil
You need to establish whether the EDS 6 solenoid current is fluctuating or not during the instability. If it’s rock steady and the engine speed is varying while the turbine speed is constant then the lock-up clutch itself is faulty. If you aren’t aware of any other problems with the transmission then I don’t see the point in replacing anything more than just the TC. There’s no need to open up the transmission to replace the converter so you don’t need a transmission specialist to do the job, any competent mechanic can do it. The critical think is to make sure that the converter has been re-manufactured by a company that is used to dealing with captive clutches, as the piston spring retainer has to be accurately re-welded back into position.
Phil
Post #487922 3rd Sep 2018 9:59pm
Andyyav
Thanks again Phil plenty to investigate!
Thinking worst case scenario (gearbox and T/C) what else would you all suggest I should plan to replace?
I’m thinking Turbos (been quoted £4800)
Egrs have been blanked and mapped out
Anything else I should consider on 2007 TDV8 143000 Miles??
Post #488009 4th Sep 2018 7:28pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Found this on the t'internet
https://auto.howstuffworks.com/under-the-h...verter.htm
Not sure I have cojones, though
Shocked 2007 3.6 TDV8
Post #488357 8th Sep 2018 4:12am
Andyyav
Me niether!!
I think my time with the pride and joy is coming to an end😢 ‘you have to remember sir at this mileage it is at the end of its life’ 😭
Post #488363 8th Sep 2018 8:13am
cheezels
Nay nay and thrice nay.
Heaps of vehicles with substantially more kays than yours and still going strong.
Very Happy 2007 3.6 TDV8
Post #488365 8th Sep 2018 8:18am
