Home > Technical (L322) > Heavy steering
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Heavy steering
Has anyone had issues with steering going quite heavy.
No bong and I haven’t checked the fault codes yet but it seems suddenly very different
Post #487770 1st Sep 2018 4:47pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Apart from checking the TPs which I presume you've already done , worn tyres can cause heavy steering after that fluid level in the reservoir , after that fluid condition ,
Is the steering notchy , check for leaks from the pipe work and check track rods ends could be seizing up
There's a few things to get you started
Have fun Thumbs Up
Post #487775 1st Sep 2018 5:56pm
Dolphinboy
Faulty BCM (body control module) - situated under passenger seat - can cause heavy steering. Do u have one or two doors with intermittent locking/unlocking problems? Then this needs changing Thumbs Up
Post #487779 1st Sep 2018 6:30pm
Teaspoonasaurous
I have one door with intermittent unlocking issue
Post #487782 1st Sep 2018 6:52pm
Teaspoonasaurous
Can this just be cleared using tool are does it require replacement?
Post #487784 1st Sep 2018 7:01pm
Dolphinboy
Don’t think it can be cleared, it needs replacing. It’s an easy enough 1/2 hr-1hr job (write up on wiki http://www.fullfatrr.com/forum/topic40009.html
It’s around £224 for a new one. There are several updated ones, can’t remember the part number but u want the latest one. Ask dan at duckworths on here (site sponsor).
Post #487803 2nd Sep 2018 7:13am
Teaspoonasaurous
Thanks
Post #487813 2nd Sep 2018 8:29am
