![]() | Home > Technical (L322) > Why TDV8 turbos fail |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Use the search function on here and type ' turbo drain mod '. Could be your issue. 2015 4.4 AB
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 28 ![]() ![]() ![]() |
Thanks, saw that shortly after posting👍
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Mikee,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Mike, spool up the secondary turbo, above 2500 rpm regularly, and it should see the smoke disappear, mine smokes once in a while when it’s not had the 2nd turbo used and had been switched on and off a few times without going anywhere. There is nothing that can't be fixed with a hammer😜😜
Markus_HH Member Since: 24 Feb 2021 Location: Hamburg Posts: 2 ![]() ![]() ![]() |
The post is already old, but the topic is actual as always. I am comming from Germany and have just purchased a RR 3,6 TDV8. In Germany we have lot´s of cars with broken engines available. About 15% of the cars in the advertisements for used cars have an engine failure. We are also driving high speed with the FF. Going up to 200 kph is very usual for the new SUVs, as big Porsche, BMW X5, X6, X7, Q series, they all run up to 250 kph on our Autobahn.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Thanks Markus, an interesting read. My 2008 tdv8 L322 now has 296,000km on the original turbos. The turbos are disabled, the Australian version has no DPF, it’s had an oil change every 10,000km, and in recent years I’ve used an engine oil flush when doing an oil change. Hopefully all these help with turbo life.
I guess you wanted to say that the EGR valves are disabled? How did you do? By blanking plate? I hope, treating the engine as you also do, that thing can run up to 500.00 km. So do the german taxicab, that are often standard Mercedes 200 or 220 cdi diesel cars. Good luck! |
Haha yes. EGRs are disabled. I have unplugged them and plugged in emulators to keep the ECU happy. But I think a remap to disable them may be a better solution. ______________________________
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
When changing the oil on both the 3.6 and the 4.4, don't forget to remove the rear drain plug to drain the turbo drain mini-sump, used for both turbos on the 3.6 and the secondary on the 4.4 so that it doesn't eventually fill with sludge which can block the turbo drain(s). |
Gday Graeme
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
With the blame partially being attributed to "driving style" and particularly warm up and cool down cycles, what would people advise in terms of max revs before reaching operating temp?
L322IT Member Since: 10 Aug 2017 Location: ITALY Posts: 17 ![]() ![]() ![]() |
I confirm |
great information, thanks |
MikeB. Member Since: 04 Feb 2018 Location: 29320 Posts: 3 ![]() ![]() ![]() |
Hi GraemeS, be so kind and put a picture in, where I am able to find this rear drain plug... best regards MikeB. 2012 FFRR 4,4 TDV8 Vogue 2010 Defender TD4 2003 TVR Tuscan S 1998 TVR Griffith 500 |
