Fuel Pump Electrical Connector Repair Kit | |
Hi Dan,
After a botched repair job from a local independent after a fuel pump failure I have had the problem re-occur. After a further inspection it looks like they have messed up the wiring harness and cables as the fuel pump looks new.
A quick look in the Electrical Library from Topix reveals its connector C0115 and carries a part number of YPC906770 with a repair kit for terminals 1-2, 5-6 with part number YPE100740 (not sure if the VUB900990 part number is relevant to anything)
Is it possible to order the connector and a wiring harness repair kit. As you can see from the photo, terminals 3 and 4 are also damaged, 4 I believe to be the main power cable with the insulation split and very loose in the connector block. There is no cross sectional area (CSA) for the cables in terminals 3 and 4 only listed as MAZA whatever that means.
I doubt if they replaced the fuel pump relay either when they fitted the new pump so a price on one of those as well would be great.
![](http://www.fullfatrr.com/gallery/albums/userpics/17373/normal_Screen%20Shot%202018-08-31%20at%2001.02.54.png) | Click image to enlarge |
![](http://www.fullfatrr.com/gallery/albums/userpics/17373/normal_Screen%20Shot%202018-08-31%20at%2001.03.16.png) | Click image to enlarge |
![](http://www.fullfatrr.com/gallery/albums/userpics/17373/Screen%20Shot%202018-08-31%20at%2001.03.28.png) | Click image to enlarge |
Hope you can help with some suggestions on the right kit to repair this,
Ste
