Home > Technical (L322) > 2.30 amps parasitic draw? 2003 L322 TD6 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I was going to suggest alternator as you seem to have eliminated most other possibilities. |
18th Aug 2018 4:10am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
I've had parasitic draws in the past on my 04 and nothing really ever showed up on any tests.
18th Aug 2018 8:50am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
^@ low
18th Aug 2018 10:55am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
nicedayforit, the thick cable that goes from the jump post on the engine side of the of the bulk head only seems to go directly to the starter motor ,am I not seeing something? |
18th Aug 2018 12:59pm |
Is there then not another cable looping from the starter to the alternator? |
18th Aug 2018 1:34pm |
I just found out there is a hiden fuse box inside the Ebox in the engine compartment which I did not see, so will pull those fuses also.
18th Aug 2018 1:48pm |
To test for current a from jump stud to alt, I place the amp meter between the lead and the stud,, I assume i need to reconnect the negative cable back onto the batter first? I don't want to damage my multmeter . |
18th Aug 2018 1:59pm |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
You really need a clamp meter to check for parasitic drains. Disconnecting cables and putting a multimeter inline will often 'wake' the car up again.
18th Aug 2018 2:33pm |
MY BAD,! it's not 2.30 Amps, I misread the new meter. its 0.230 amps.
19th Aug 2018 6:50am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
0.23 amps is still not good...
19th Aug 2018 10:49am |
Update, I found a shorted couple of wires in the spare well, they were for my reverse camera i had installed in the bumper a while ago, the wiring had rubbed through on the body work. The pos wire seems to be live and is shorting to earth. this may be my problem. . |
25th Aug 2018 12:26am |
