Home > Technical (L322) > hidden menu 05 l322 td6
delticdenny
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi all, I cant get the hidden menu to open when I hold down the right button on the cluster and turn on ignition to position 1 check ok comes up, test nr01 does not is this normal cheers
Post #487032 24th Aug 2018 5:57pm
holidaychicken
Do you have touch screen display?
Post #487039 24th Aug 2018 7:01pm
delticdenny
Yes I do thanks
Post #487040 24th Aug 2018 7:07pm
holidaychicken
Don’t think it will work, the hidden menu is a BMW thang, you have a change over model to JLR. I had a TD6 06 that had the touch screen and wouldn’t access the full hidden menu, only the bit you got.
Post #487043 24th Aug 2018 7:11pm
delticdenny
Thanks for that
Post #487063 24th Aug 2018 8:54pm
holidaychicken
Post #487064 24th Aug 2018 9:00pm
