Home > Technical (L322) > Suspension woes
Andy
Suspension woes
I’m losing the will to live with my suspension. I’m using the iid tool and it’s showing no faults. Yet I get air susp inactive on the dash. The suspension rises to off road mode on the front when I switch off the car and I have to use the iid tool to lower it in the “test valves” menu. Once I re-enable the EAS it creeps back up to off road height again.
Can anyone assist?
Post #486902 23rd Aug 2018 10:26am
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
Are front level sensors working properly? -08 3.6 Vogue
-87 951
Post #486903 23rd Aug 2018 10:45am
Andy
As far as i know, yes. I did find a fault using iid tool suggesting the left hand one was at fault so I ordered a new one. However when I went to fit it, I noticed a break in two of the wires to the sensor. I soldered them and that fault cleared but now I’ve got this problem instead.
Post #486907 23rd Aug 2018 11:35am
Any reason why your steering angle sensor could be out of position. Steering wheel off?, wheel alignment done? Track rod ends replaced?
Post #486911 23rd Aug 2018 12:12pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Assuming you rewired the sensor correctly, it's very strange that your IIDTool is reporting no faults.
My first thoughts were either a knackered height sensor or leaky valves, but I would have thought either of these would lead to faults being logged.
Might be worth having a look at the live values when running just incase there's anything strange visible (compressor always running for example or system pressure varying or one of the height sensor readings being completely out of whack).
Post #486932 23rd Aug 2018 4:19pm
Symptoms do point to a height sensor... .
Post #486940 23rd Aug 2018 5:16pm
kimlahti
Have you tried EAS calibration with IIDTool? -08 3.6 Vogue
-87 951
Post #486942 23rd Aug 2018 5:31pm
Andy
I have tried. Not sure if I’ve done it correctly as all I could find was manual calibration. All the setttings in there were 139 and 156
I’ve also tried “test valves” and set the height followed by “exit and keep test mode” to stop it rising and falling. That works for a it then the front drops slightly after a few days.
Post #486952 23rd Aug 2018 7:08pm
I thought it went up to off road height ? .
Post #486972 23rd Aug 2018 9:25pm
stu1
Ah yes, our old one (2002) I drove like this for quite a while before I managed to get around to fixing it. The problem in my case was the rear left height sensor lever kept popping off and I got sick of reconnecting it so just drove with the EAS in test mode and manually adjusting as necessary.
Assuming it is dropping when you've disabled it by leaving it in test mode, this indicates you have slight leak, but that's a secondary problem - you need to find the cause of it becoming inactive in the first place.
(Eventually I fixed the height sensor properly as I wanted my suspension working again Smile )
Like I said above, check the live values - there may be a clue there.
Edit: Note, that if it does indeed creep up with the EAS in test mode, it may indicate a leaking valve or valves (the main valve block is in the sill under the drivers door on yours).
Post #486973 23rd Aug 2018 10:34pm
Andy
IT doesn’t creep up in test mode. It’ll stay where I leave it. It probably takes a good three weeks to drop a couple of millimetres.
I wasn’t sure if I was meant to drive around in test mode but it doesn’t seem to be a problem so that’s what I’m doing until I can work out what’s going on.
That said, I’ll be towing next week so I hope it’ll be ok.
Post #486984 24th Aug 2018 8:01am
