Home > Maintenance & Mods (L322) > Transfer box oil
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Transfer box oil
Hello
Can anyone tell me if the special transfer box oil is all the same there seems to be a different number for the year change on mine which is 2006 , 3.6 tdv8
Does anyone know how much LR will rip me off for said oil
I've got new engine oil and filter and 3lts of syntax 75/90 so I thought may as well do all the oils as I've have no history on there last change other than the sevice book saying sevice to spec .
If the cars up for oil change I will get the front diff and transfer box at the same time then up the ramp for the rear diff
Cheers Thumbs Up
Post #486706 21st Aug 2018 8:19am
RRPhil
2006 was the year when Land Rover drastically changed the diesel L322 driveline (for 2007 model year) from:
3.0 TD6 BMW diesel engine (130kW/390Nm)/GM 5L40-E 5-speed transmission/New Venture NV225 transfer box
to
3.6 TDV8 Ford diesel engine (200kW/640Nm)/ZF 6HP26 6-speed transmission/Magna Steyr DD295 transfer box
You therefore have the later transfer box (which, incidentally, Land Rover are still using today) which is fitted with an electronically-controlled slipping wet multi-plate clutch to provide a centre differential lock and torque biasing between front and rear propshafts.
It’s therefore very important that the fluid you use has the correct friction modifiers to suit the clutch’s characteristics, so you should only use the recommended Shell TF0753 fluid (capacity = 1.5 litres).
Phil
P.S. The earlier New Venture Gear transfer box also used a special fluid, Castrol BOT 26 FMB 1 75W-90, to suit the friction characteristics of its Torsen Type-B centre differential (capacity = 1.0 litre)
Post #486727 21st Aug 2018 11:07am
Henda
Wow cheers mate so that's me off to Landrover to get the correct oil Thumbs Up
Post #486810 22nd Aug 2018 6:54am
Henda
Not a bad price from north east Landrover it was £25 per ltr and yes because of the year it is the latest type of oil Thumbs Up
Post #486920 23rd Aug 2018 2:02pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi Henda
Did you change it then?
Any ups or downs? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #586470 6th Mar 2021 11:41am
