Home > Technical (L322) > Forcing DPF regen at home
torjak
United Kingdom 2011 Range Rover Vogue 4.4 V8 Galway Green
I have a MY11 4.4 TDV8 and have managed to get myself a red DPF full light while on the way to clear an amber light.
Annoyingly all the local garages are full up for at least a couple of weeks.
Has anyone had any luck forcing a regen with the likes of an icarsoft or Autel? The marketing on them suggests it’s possible but I’ve not found anyone who said they have done it.
Thanks.
Post #486803 22nd Aug 2018 7:32am
GGDR
I had exactly the same thing. Was your fuel below 1/4 when it happened?
It's not possible to clear a RED yourself, even with an iCarsoft. I tried!
Pls see my DPF Full guide!
http://www.fullfatrr.com/forum/topic48068.html
. Cheers, Greg
Post #486804 22nd Aug 2018 7:34am
GGDR
Where abouts in London are you?
. Cheers, Greg
Post #486807 22nd Aug 2018 7:40am
torjak
Thanks for the reply, I saw your post already. I need to check how much I have in the tank. I was vaguely hoping for some more positive responses on DIY solutions before I plump down the cash probably in vain.
I’m in SE21.
Post #486808 22nd Aug 2018 7:50am
GGDR
Well somebody might chime in here with a golden answer.
But I spent a lot of time trying to solve it and as far as I can tell there's no way.
That place in Hendon is good (a bit far from you though), if you've got high milage you might want to consider a full remove and clean like I did.
But I've had two other REDs cleared by garages so you can just go that way.
You need to find the cause, if you've got an IIDTOol, check for the P040D-00(2F) error.
. Cheers, Greg
Post #486811 22nd Aug 2018 7:57am
torjak
I've been living with relatively frequent amber warnings so I definitely need to track down the problem.
Out of interest, how low could you get your soot levels before you had your DPF properly cleaned?
Post #486815 22nd Aug 2018 8:49am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I have an autel 802 and don't think you can Initiate a dpf regen from it.
For that you need one of their other tools, like 808 I think. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #486825 22nd Aug 2018 9:54am
GGDR
You can monitor soot levels with an IIDTool
Most owners interested in maintenance or troubleshooting (that's every owner right?) have one, secondhand around £300, new around £400. Otherwise you can spend your money at your trusted garage. They have pro tools costing thousands that can deal with your RED.
. Cheers, Greg
Post #486826 22nd Aug 2018 10:02am
