![]() | Home > In Car Electronics (L322) > igo nav software on 2010-2012 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8710 ![]() ![]() ![]() |
from memory when I read up on this a while back the machine they use is basically a HDD which is plugged into the FireWire port. The head unit itself then searches for the new mapping data on the external drive and updates itself.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35532 ![]() ![]() |
if the hdd can be made to run win-ce then igo primo could be a choice of nav software.. ... - .- -.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2582 ![]() ![]() ![]() |
The connector, which is accessible with the lower glove box open, is not the same very small 4-pin Firewire on the lead that I bought, instead more the size of 6-pin Firewire but not the shape nor the pin positions. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
If you want to pm me a number, preferrably fixed line, I have maps on DVD. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
in addition to johns offer i have the iso for download if it helps. ... - .- -.
Could be a FireWire 800 connector. Can’t remember exactly, the update device is simply a HDD I’ve seen a pic of it, I think there’s instructions in rave with a special tool number, which you x ref on the net for a pic.
Firewire 800 uses 9-pin from what I can glean. I don't think that 800 would have been out long enough to be ready to be used in vehicles sold Aug 09 considering development to production lead-times. |
You could buy the 1m cable from the LR tool store....price is a snip at £300.....
A USB-A plug with the metal shield removed fits nicely into the socket and has the same contact spacing. I have a short USB extn lead with the metal shiedl removed that then plugs into a USB to FW 4-pin lead that is straight through pin for pin. As most FW PC adaptor cards have 6-pin and 9-pin fw sockets, a 4-pin to 6/9 pin adaptor would also be needed.
Hi,
The connector
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Please post cost of head unit and if you have paypal i can share the cost with you. 2015 4.4 AB
Thought I’d taken a pic......
