Home > Maintenance & Mods (L322) > Exploded Parts Diagram
Northern lad
Morning All
Does anyone by chance have a PDF they would kindly share? I found one for my previous car, but have had no luck trying to find one for my RR, I believe mine sits in the 2002 - 2005 range
in case anyone doesn't know, its a detailed part number document, which is in pictorial format, showing just about every part associated with sections of the car e.g. front end, grille / bonnet / wings / air vent / washers etc the images are just sort hovering over the area the parts come from, and have their respective part numbers next to them (i hope that makes sense, and apologies to those that think i'm insulting their intelligence, no such insult meant Bow down )
i have tried to attach a PDF from my last car so you can see what I mean, but without any luck, hopefully the screen print works
regards
Steve
 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #486440 18th Aug 2018 8:23am
GGDR
Steve you need the "microcat" - in the wiki section.
There are two, I've been using this one: http://lrparts.ru/engl/
. Cheers, Greg
Post #486442 18th Aug 2018 8:32am
p38arover
Australia
Or the new site: http://new.lrcat.com/ Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #486445 18th Aug 2018 8:46am
or, this site,
http://allbrit.de/LR.cfm?SPRACHE=EN
all 3 links are in the wiki btw.. Thumbs Up ... - .- -.
Post #486446 18th Aug 2018 8:49am
Northern lad
gonna go double
many thanks for that, I have had a look (unless i'm doing something wrong?) it doesn't give me the detail i'm looking for, as in the screen print in my post. don't mean to sound ungrateful by the way Thumbs Up
Steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #486447 18th Aug 2018 8:50am
Northern lad
Thanks Chaps your help is appreciated Thumbs Up
Stan that link is just about spot on for me, however i'll tell you what it is i'm trying to find in more detail, when you open the upper tail gate on either side (inside pillars) there are plastic thingys? one each side, I believe there should be a rubber bumper of sorts that sit over the two plastic thingys (that's about as technical as I get at the moment) to cushion the tailgate when you close it, if i'm right, mine are missing, I'm also interested in the tailgate straps one of mine has been snapped, ive seen them on e-bay, but would prefer to go to a reputable supplier, rather than take a punt on e-bay, there are lots of little pieces I would like to replace all the wiper blades, interior bits and so on, but its just those rubber things that are annoying me ATM
do you know of a site or link that I can download the document from?
regards
steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #486451 18th Aug 2018 9:39am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
You need to ask Dan from Duckhams here on the forum for your parts requirements - very good prices and service... Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #486452 18th Aug 2018 9:44am
nino_nino
Northern lad, here is pic of the tailgate stop/distancer-
when I bought my car one was missing, so I fashind one from M8 40mm ss bolt and two O rings glued to the head with super glue. added some teflon tape in the middle and it worked real well. it was like that for over a year till, I found replacement.
Nino,
Post #486461 18th Aug 2018 11:54am
Northern lad
Nino thank you they are the plastic bits i'm talking about, I just presumed there was a rubber pad or something on top, right then its just a case of adjusting outward for the upper tailgate to hit / sit on.
thanks, that really, really is a great help Thumbs Up Thumbs Up Thumbs Up
still looking for the document though, and i am making a presumption, that if its available for jaguar, then something similar will be available for the RR 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #486473 18th Aug 2018 2:22pm
p38arover
Australia
stan wrote:
or, this site,
Unfortunately, that site doesn't give LR part nos. - otherwise it's a good 'un. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #486516 19th Aug 2018 2:29am
