Home > General (L405) > 2015 range rover autobiography deployable towbar
But there's no sensible place to store it in the car - so you either leave it fitted or at home in your garage - or at least I did one time Embarassed It was on my garage floor in England and went to get my boat out of storage in Bordeaux..... fortunately the local MD had one in stock - but an expensive oversight.
Post #486369 17th Aug 2018 12:39pm
CS
What I do is put it in the recess on the right of the loadspace. The LR fitting instructions show it tied to the ring at the near right corner to stop it moving about, using the strap on the holder bag. That seems to require the bar to sit on the main floor of the loadspace, inconvenient for loading other things, and also if a loadspace liner is in place. So mine is tied to the ring with a length of rope attached to the strap on the holder.
The slight element of faff with it is that one needs to have a 16mm spanner/socket so that the anti-rattle bolt can be tightened, if one is very fastidious about exact torque settings then also a torque wrench. Some (earlier) hitches seem not to have that bolt, and one can tow without tightening the bolt, albeit with some noise from the bar moving in its socket. Only Range Rovers since 1988
Post #486370 17th Aug 2018 1:07pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
What CS said! (Bottom of page 1) Thumbs Up
And it gives a choice of towing fittings (mine’s a Dixon Bate combination tow ball and pin) and it means you can add a protective plate to stop your rear bumper getting damaged by the trailer’s draw bar.
I never remove it when not in use (its far for effective than the rear bumper), it’s always ready when I need it and besides, a proper tow bar never looks out of place on any Land Rover with a 3.5 tonne towing capacity Very Happy I can see why people might might want to conceal the retractable one though Laughing
Post #486383 17th Aug 2018 3:08pm
Or you can learn to reverse properly and use the camera Whistle
Rolling with laughter They do look a bit Censored without a trailer attached
Post #486394 17th Aug 2018 5:06pm
Red Merle
Laughing
Actually, it’s more of a case of doing the final bit of manouvering of the draw bar of a laden, unbraked, trailer on a steeply sloping drive Thumbs Up
Post #486396 17th Aug 2018 5:28pm
smartymarti
United Kingdom 2014 Range Rover Vogue SDV8 Corris Grey
Went to use mine today and the electric 7 pin socket has sieved up inside , I’m told there’s a remake for these but my local dealer isn’t very helpful , anyone shed any light on these please
Post #497482 3rd Dec 2018 8:49pm
It seems to be a 'known' problem that the electric socket can seize - I've heard of a few being done under warranty, but not sure outside of that.
Is your's 7 pin ? I thought they were all 13.
Post #497523 4th Dec 2018 8:56am
smartymarti
I’m asuming it’s a 7 -in as I can get it down to confirm iv found a part no of a service kit
VPLGT0138
Going to try and see if I can order it
Post #497526 4th Dec 2018 9:00am
Yours is an L405 ?
If so, your profile needs updating Wink
Post #497534 4th Dec 2018 10:02am
smartymarti
Cheers totally forgot to update
Post #497535 4th Dec 2018 10:04am
smartymarti
the bracket was ordered from
https://www.lrparts.net/vplgt0138-bracket-socket-support.html
these are cheaper than main dealer
delivered tomorrow so ill try to do i write up it possible
Post #497548 4th Dec 2018 11:43am
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
I bought a deployable as a dealer fit as per post 3 on this thread. Since then I've towed my 2.5T caravan to Italy, France and Spain. It failed to lock when moving from Italy to France so I called LRA. They sent a guy to look who was from Essex but was doing the AA thing in France for a period of time. He checked it and found the sensor to be blown which confirmed the bar had locked. He said the bar had actually locked and the sensor couldn't confirm so, which is why I had messages on the screen. He assured me (In writing) that it was safe to use, which I did and it was. I have since had the whole thing changed and it's worked without fault since. It gets plenty of use and I haven't had any cause for concern since. I love it.
Post #497550 4th Dec 2018 11:46am
smartymarti
my local lr specialist has a full deployable system complete with fitting £700 if anyone is interested
Post #497556 4th Dec 2018 1:44pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Crap, I’m miles away, wonder if he would swap for a set of 4 style 8s Mr. Green
Post #497562 4th Dec 2018 2:11pm
FredB
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Looking to get all the parts for a deployable tow bar for our new l405, do you guys know if the extra battery bracket is included when you buy the actual tow bar part?
Post #522399 21st Jul 2019 4:10pm
