Home > Technical (L322) > Toe links rear
petebowling
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
Toe links rear
Can anyone throw light on how to remove the nut off the buckle joint end have tried heat ,plenty of wd40 and I can't get a grinder in. Crying or Very sad
Anyone have any special tricks I don't know of to release it : Bow down
Post #486316 16th Aug 2018 7:47pm
If you mean the one at the hub, I used a hacksaw on one side and a grinder on the other, along with a bit of help from a cold chisel Twisted Evil
There are some photos in my rear end teardown thread, Day 3
http://www.fullfatrr.com/forum/viewtopic.php?t=17399 .
Post #486342 17th Aug 2018 7:06am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Do you mean the inboard end?
Electric reciprocating saw with 8 inch metal blades did ours - cut through both ends of the bush & bolt. Went through a few blades though as material is not soft.
Outboard end came undone with just spanners & wd40 Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #486348 17th Aug 2018 7:52am
