Home > In Car Electronics (L322) > Nextbase Dashcam - Hardwire Installation
iani
2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I'm trying to fit a Nextbase hardwire kit, I've run the cable under the headlining and down the windscreen side airbag cover, I'm following the process as shown here: http://www.fullfatrr.com/forum/topic23389....g+dash+cam
The passenger side trim needs to come off, however, mine has the airbag on/off switch in it, does this panel just pull off or is the switch a problem here?
Ian 4.2SC; 1960 TR6; XF Sportbrake
Previous:
Jaguar XF Sportbrake
Landrover P38 4.6 Freelander x2
Mitsubishi Shogun 3.2 x2
BMW M3 Conv x2; 840Ci; M Coupe; 325SEx2
Mercedes C180x2
Vauxhall Vectra 3.0D Cavalier & Astra Sri; Corsa
Ford Mondeo Escort Mk2
Triumph 11 owned
VW Type2
ISUZU DMAX
Post #485806 12th Aug 2018 3:50pm
Weegie
I have just fitted same today- Nextbase 412. My airbag switch is on the panel on the side of the fascia. I removed it to get to the side of the fusebox. It was only a question of disconnecting the plug once the panel was free.
Someone may know differently but I would think the process would be the same for you.
Edit: I think I misunderstood and thought you meant the switch was on the side of the windscreen. On reviewing it I believe you mean the same as me. The panel referred to is the triangular one exposed when the door is open. Just release it and disconnect the plug. John
GAP iiD BT-Sold
Post #485807 12th Aug 2018 4:09pm
iani
Thanks Weegie, one more question if I may, where did you connect the Earth to?
Previous:
Mercedes C180x2
Triumph 11 owned
VW Type2
ISUZU DMAX
Post #485814 12th Aug 2018 5:16pm
Weegie
I drilled the frame that the side panel plugs into and used a small nut and bolt. I have used a self tapper on a previous ff John
GAP iiD BT-Sold
Post #485815 12th Aug 2018 5:20pm
iani
Thanks, sorted now, I earthed it to one of the screws holding the glovebox on, works fine. I was being too gentle with the side panel, it came off fine with a good tug.
Previous:
Mercedes C180x2
Triumph 11 owned
VW Type2
ISUZU DMAX
Post #485816 12th Aug 2018 5:33pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Power
All the power you need is in the sunroof switch area, I wired and fused mine in there, much easier and tidier. Many thanks
Paul
Post #485819 12th Aug 2018 6:05pm
kooky_guy
Pvw10 - That sounds interesting. Any more information?
I'm planning to hard wire mine at some point (probably when I do the deployable steps) so I'd be interested in doing it there. 2010 4.4 TDV8 Vogue SE
Post #485904 13th Aug 2018 10:30am
Pvw10
I bought one of those little 12 to 5v converters added an inline fuse and snatched into the sunroof power as ignition controlled.
Easily enough room, only one short wire to the unit visible. Many thanks
Paul
Post #485907 13th Aug 2018 10:57am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Is this what you used / https://www.ebay.co.uk/itm/DC-DC-Step-Down...SwNmNakk7W
Post #486622 20th Aug 2018 12:37am
Pvw10
Yes or very similar, I ordered from China and bought for about £1.50 each so bought 5 so could do other vehicles.
Worked a treat. Many thanks
Paul
Post #486639 20th Aug 2018 10:03am
DaveK
Did you bury it behind the front interior lights consul and if so, how did you remove the big plastic cover with the lights and sunroof switches in ?
Post #486640 20th Aug 2018 10:17am
Pvw10
I removed the smaller piece, the little vented panel from memory by the roof switch, plus dropped the actual rocker switch out. Then you can do it all externally then push all the bits back in through said panel.
Had to fiddle a bit to get the wire to the cam so just worked it through and round, it can be poked under etc.
There was no need to remove the whole cluster that’s for sure. Many thanks
Paul
Post #486642 20th Aug 2018 10:27am
heres an ebay UK one for £2.89 and quicker delivery but with an usb socket...
https://www.ebay.co.uk/itm/DC-DC-Converter...SwxblbMudv
Post #486644 20th Aug 2018 10:50am
DaveK
Pvw10 wrote:
I removed the smaller piece, the little vented panel from memory by the roof switch, plus dropped the actual rocker ......................................
Cheers for that.
Post #486645 20th Aug 2018 10:53am
