If one sensor goes down, it takes the rest with them (well at least it did with me) and this was a broken wire on one of the sensors
Diagnostics should tell you which one is causing the problem, if an inner one most likely front bumper cover will have to come off, you may be able to get at the outer ones by bending back the wheelarch liners. .
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember
