Home > Maintenance & Mods (L322) > Start up rattle - Worth doing an engine flush?
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Here we go again with the next issue Whistle !.
I have the start up rattle & it's possibly getting worse. I believe it to be the hydraulic lifters rather than the Vanos because It's only there on initial start up & as I rarely use the vehicle (once a week) it quiet on subsequent start ups.
2006 4.4 AJ V8 petrol.
I'm in the process of changing all my fluids later this month, including engine oil & filter. Now is worth doing an engine flush to see if this cures it before replacing the oil.
Has anyone tried this or is a waste of time?.
Post #485115 3rd Aug 2018 8:25pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
I used a flushing oil before putting expensive oil in (Magnatec) and it has not made the slightest difference - often wonder if some kind of delay on the coils firing would solve the problem - the idea being that the engine spins over for 3 or 4 seconds before firing up to allow oil pressure to build? 04 4.4 petrol.
Post #485132 3rd Aug 2018 11:48pm
Highroller
That would be ideal, some sort of immobilizer just to allow the oil pressure to build up. I won't be bothering with an engine flush, as not heard one good thing as a result of doing this.
Post #485145 4th Aug 2018 8:33am
