Home > Technical (L322) > doors and battery
delticdenny
Ireland 2005 Range Rover SE Td6 Bonatti Grey
doors and battery
Hi Lads, can the front passenger door lock be switched with the back one to see if its faulty. I replaced the drivers door cable and battery went flat charged it up sync the key and front passenger door wont lock or unlock with key or fob or switch on dash. I took both door cards checked all connections everything good checked fuses also battery charges at 13.5 v with engine ticking over then settles at 11.5v when off, any ideas cheers
Post #485130 3rd Aug 2018 11:44pm
delticdenny
sorry lads its a 2005 td6 vogue
Post #485131 3rd Aug 2018 11:45pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
If battery is only showing 11.5 volts with engine off I think the first thing for you to do is fit a new battery sir !
Post #485133 4th Aug 2018 12:12am
