Home > Technical (L322) > Drivers seat not working
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
hi everyone had a good few trouble free years with the full fat, went out in the car this morning pressed number 2 on the seat all worked fine. wife went out in it an hour after i did and pressed number 1 and nothing is happening??? check fuse and that is all good as passenger seat is still working!!! could this be an ECU fault???
Russ If i could would you!!!!
Post #485007 2nd Aug 2018 1:30pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Russ
Have you tried both fey fobs ? could be a low battery in the fob;
Laurie
Post #485025 2nd Aug 2018 9:30pm
Weegie
Have you tried setting up the seat and memorising 1 again? Could be that the memory has got lost through a glitch of some sort. John
GAP iiD BT
Post #485040 3rd Aug 2018 6:17am
Clivefog
Plug come apart simple reconnect?
Post #485045 3rd Aug 2018 7:23am
