![]() | Home > Technical (L322) > Suspension trouble. |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
I pulled away from a set of lights starting to turn right.The front of the car rose so much that I couldn't see the road in front of me. Pulled over and got out to find the front wheelarch was about350/400mm above the wheel and the rear was all but touching the wheel. I tried to lower the front with the idtool. Nothing altered. Had to get recovered by the AA and intend to have a look at things tomorrow. If anyone has had anything like it or can offer any ideas what it can be I would like to hear. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
See here: (from wiki)
Thanks for that Joe. I spent the best part of Sunday searching before I posted but didn't see that one. I will know in the next hour or so if that is the problem. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
The filter was completely blocked. I guess that will cure the problem but I found the piston was well slack in the bore so have ordered a repair kit from ebay. Should be here on Wednesday so will know then. Many thanks for that Joe as I don't think I would have thought to look at the filter. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
