Home > Maintenance & Mods (L322) > Electrical gremlins due to Light Control Module?
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
So the wife went to work and said the turn signals stopped working. Right and left. I go check it out to find signals not working but flashers were. No sound but they would flash. The first disturbing part was I couldn't find a fuse to check. Couldn't find it in RAVE either. So we switched cars. On the way home I tried the left signal. Nothing then 10 seconds later, with the switch off, it comes on and wouldn't shut off. Then it did. Same with the flashers. Then the seatbelt warning came on. Then off. Then the Air suspension inactive warning. Then off. Finally I noticed the infotainment screen was off and the system wouldn't come on. A few months ago I did the $7 amp bypass on the BM54 and fixed it. Lots of hum from poor grounding but at least I could change my settings.
I first suspected water in the system due to monsoon like rain for 4 days but everything in the boot was dry. I pulled the stereo fuse for fear of another battery drain and rechecked the signals and hazards. Both back to normal.
Anyone know if a screwy BM54 can cause havoc elsewhere in the electronics? Thanks
Post #484254 24th Jul 2018 6:49pm
I had this intermittently and could not find a solution.
However, quite separately, in resolving a battery drain I took the satnav unit apart to find corrosion on the PCB, cleaned this up and battery drain gone. All the stuff in the boot is more or less somehow on the same fuses/circuit - Satnav/Radio/On Board Computer etc.
Might be worth a look see Thumbs Up .
Post #484272 24th Jul 2018 9:53pm
doclees
Thanks. I spoke too soon that pulling the infotainment fuse gave me back signals and proper hazards. Went to run to the store and they are still not correct. So maybe bad relay? Back to the wiring diagram.
Post #484276 24th Jul 2018 10:28pm
doclees
I'm believing the problem may be in the LCM. RAVE says needing Testbook 4 to reconfigure a new one. Are these vehicle specific or can I swap in another one from a 2004?
Post #484315 25th Jul 2018 2:47pm
doclees
OK this all may be a big "never mind". In pulling LCM to look for corrosion I first disconnected the battery ground. Well it pretty much came off on its own. For completeness sake I pulled the LCM and found no corrosion on pins or board. I added a couple of lock washers to the ground clamp. At this moment the problem is solved.
I still would like to know if in the future if the LCM is replaced will it need a Testbook 4 reset.
Post #484318 25th Jul 2018 3:59pm
Some have just been able to replace the LCM without problems (2nd hand) whilst others indicate some recoding is required (possibly new ones ?)
Search the forum for a haystack of results on the "LCM" .
Post #484322 25th Jul 2018 4:37pm
Weegie
"I first disconnected the battery ground. Well it pretty much came off on its own."
Could that have been the cause of the problem? ie. intermittent current drops. John
GAP iiD BT
Post #484324 25th Jul 2018 5:38pm
doclees
Yes seems to be. Looks like it killed my infotainment screen. Time for an Android unit.
Post #484325 25th Jul 2018 5:54pm
steptoe
I replaced my LCM with a secondhand one and it worked perfectly without any re-coding required.
Only thing that altered is a "dot" in front of the recorded mileage which shows that a part has been changed.
Post #484363 26th Jul 2018 10:42am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
The LCM contains the about 1/3 of all the vehicles configuration, if the doner vehicle is of the same spec and has the sam factory options fitted/enabled then it will work. However you may find that the doner vehicle had different options fitted/enabled and some systems may no longer work on your car until it is recoded.
The tamper dot on the instrument cluster means that the millage in the instrument cluster, EWS and the LCM do not match.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #484389 26th Jul 2018 4:02pm
doclees
Thanks folks, I may be back to swapping one out. Wife just texted the signals not working again. My iidtool has shown low voltage errors for the headlights since I purchased both RR and tool about 50k miles ago. This is why I was looking at the LCM. Maybe the loose ground cable was just coincidental.
Any way to test if the LCM is defective? Would a Testbook 4 evaluation find it?
Post #484394 26th Jul 2018 6:04pm
doclees
Current update is that signals worked fine on way home wife says but added she didn't have lights and A/C going so less electrical stress. I'll try it later with lights wipers AC and radio.
Post #484421 26th Jul 2018 10:50pm
doclees
Update: do the following faults point to LCM errors? 0x2A headlight (RL) ignition voltage <7 5 volts, 0x88 I-Bus fault, 0xBE Lightning Control Module error, LCM-Light Control v11, 0xC ECU EEPROM fault. I don't remember the lighting control faults being there in the past.
Post #484494 27th Jul 2018 11:13pm
Try clearing the faults then (does this fix anything?)
1. See what comes back immediately
2. in a few days .
Post #484495 27th Jul 2018 11:45pm
doclees
At this moment all is good. I took it out with lights/wipers /AC/hazards /radio. No issues. Checked live battery voltage -13.9. I will go clear them. I know the list was holding the left signal bulb out fault. I replaced the bulb just before this all started. Hmmmmm.
Post #484496 27th Jul 2018 11:56pm
