Home > Technical (L322) > P0705 code - dealer wants to replace the gearbox
macka
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi all. I'm a first timer with a question please. I have a 2006 Range Rover 4.4l that is throwing up a P0705 fault code, indicating problems with the range sensor/neutral switch. The friendly dealer is suggesting he needs to replace the whole gearbox to fix this problem at a cost of £5500. That feels like overkill, surely? Wouldn't it be more likely that a replacement of the mechatronics unit would solve the problem? I'm not sure what they cost, but hopefully a lot less than £5500 - more than the vehicle even cost! Thanks!!
Post #484303 25th Jul 2018 10:53am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Try sending a PM to RRPhil on here, he is the gearbox guru!
http://www.fullfatrr.com/forum/member-rrphil.html
Post #484305 25th Jul 2018 12:19pm
macka
Thanks, Paul. I tried to PM RRPhil, but as a newbie it looks like I need to have three posts under my belt before I have PM rights! Hopefully he'll see it on the forum and dive in. cheers
Post #484307 25th Jul 2018 12:23pm
PaulTyrer
There are a couple of topics on here.
http://www.fullfatrr.com/forum/topic38318.html
http://www.fullfatrr.com/forum/topic6992-15.html
Post #484308 25th Jul 2018 12:36pm
macka
Thanks. I'd seen the first, but not the second. Will dig in for clues! Appreciated.
Post #484310 25th Jul 2018 12:48pm
GraemeS
Haven't you now made 3 posts?
Post #484311 25th Jul 2018 12:53pm
RRPhil
As I’ve previously stated, P0705 errors are relatively common for the ZF 5-speed with its external inhibitor switch (which is open to the elements) but it would appear that this error is now becoming increasing common on the early 6-speed units too, despite the fact that the inhibitor/gear position switch is internal and of the non-contacting type.
Unfortunately, I don’t think we’re any nearer diagnosing the exact cause but, worst case, it may entail replacing the mechatronic unit – but certainly not the complete transmission!
I think my advice would be to remove the mechatronic unit and send it to Pete Stirrup for testing (www.valvebodyuk.co.uk). Maybe even consider have the solenoids replaced at the same time if you’re thinking of keeping the vehicle for a while, simply to reduce the risk of further transmission issues further down the line.
This should cost £100s, not £1000s.
Just a reminder that the mechatronic units are coded to the vehicle, if you source a replacement.
Phil
Post #484319 25th Jul 2018 4:04pm
What next from LR dealers?
Owner: "Hello, my car won't start"
Dealer: "We have done the diagnostics (charge £200), you need a new car" Rolling with laughter .
Post #484321 25th Jul 2018 4:35pm
macka
Incredibly helpful info, Phil. Thanks so much. It all makes perfect sense. I may end up replacing the mechatronics unit completely so it's "future-proofed", but still better than a new gearbox price! These dealers wonder why people hate dealing with them...not too hard to figure out.
Post #484352 26th Jul 2018 7:52am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
To be fair, a Landrover dealer is absolutely the worse place to take a 12 year old Range Rover. The techs don't have the experience, they rely on the factory and their laptops and the TSB's on the latest models. They aren't interested or have the experience in stripping down something like a gearbox and trying to diagnose a problem - its easier for them to just take the path of least resistance and switch out the whole thing and charge you full price.
The experience on vehicles like ours is out with the indies who work on these cars day in and day out. And are usually half the hourly rate. And no doubt a large portion of that outrageous rate is being spent by the dealers looking up the problems and working out what to do - you'll get far better value for money and knowledge out with a trusted independent who will just get on with it. Thats just my 2p worth anyway Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #484412 26th Jul 2018 9:17pm
