Home > Technical (L322) > 2003 4.4 petrol struggles to fire when hot.
Zambezi
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Some advice please.
I've had problems starting my 4.4 V8 L322 since December when it wouldn't start at all during temps below zero.
Once the weather had warmed up it started from "cold" without any problem.
Once hot though, 50% of the time it will crank over (very healthy speed) and then splutter into life seeming to be firing on only a few cylinders but then it clears and runs perfectly. The other 50% of the time it fires up straight away.
Once running is seems to run perfectly.
The engine management light would also randomly come on whilst driving.
Fault codes showed 2 lambda sensors were knackered. All 4 lambdas were replaced but still struggled to start.
Since then the following have been replaced:
Fuel pump
Fuel filter
Fuel purge valve.
Local independent garage (Mansfield 4x4 in Bury St Edmunds) don't know what to do now.
Engine light is on again, showing P0430 - Bank 2 CAT Efficiency Below Theshold.
Can anyone suggest where I should look to get the starting problem sorted please, which may well be related to the most recent fault code,...... getting fed up with garage bills and not curing the problem.
Thanks
David 2002 4.4 V8 with LPG
Zambezi silver
Post #484103 23rd Jul 2018 8:25am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
HiDavid have you had the plugs done ? Check for air leaks and possible oil leak on rocker cover gasket contaminating plugs and coils .Dirty injectors? Is she Lpg?. Good luck
Post #484107 23rd Jul 2018 8:54am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
sounds to me like ignition coils Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #484109 23rd Jul 2018 9:02am
Zambezi
I replaced the plugs about a year ago, some 5,000 miles. There was oil in the plug holes so the cam cover gaskets do ideally need replacing.
Would a faulty coil pack not create a fault code ?
It's the absence of fault codes that Merelander 4x4 are struggling with, they don't know what to look for.
I'd like to know if anyone can recommend another independent LR specialist who understands the BMW 4.4 engine. 2002 4.4 V8 with LPG
Zambezi silver
Post #484110 23rd Jul 2018 9:07am
rik
I would definitely check coils nor doing any harm giving them a clean . Misfire will throw up all ki nds of probs especially when it is intermittent .Will also damage catts
Post #484115 23rd Jul 2018 9:32am
Zambezi
Thanks. Will do.
Do you know which side of the engine is "Bank 2" as this is the bank causing the engine light to come on ? 2002 4.4 V8 with LPG
Zambezi silver
Post #484118 23rd Jul 2018 9:43am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Hi David,
Bank two is on the left side / near side when sitting in the drivers seat on a RHD vehicle.
Regards
John
Post #484119 23rd Jul 2018 9:44am
rik
Bank 2 I believe is passenger side do you have lpg?
Post #484120 23rd Jul 2018 9:45am
Zambezi
Thanks Rik
Yes I have LPG installed, a Romano system installed in 2006.
I've just booked the car into a LPG installer to see if anything is wrong with that system as the car will unexpectedly cut out on LPG and I have to run on Petrol.
Are you aware of specific issues when a LPG system is fitted ?
Cheers
Zambezi silver
Post #484124 23rd Jul 2018 9:52am
rik
Yes eml light can come on intermittent fault codes pointing to lean mixtures at lamda mine been doing it for years no prob just gas to clean .Gas service should fix any problems .How long since last service ?I changed out vaporizer and filters as well as injector cleaner this year suspected diaphragm leak not expensive .Gas injectors need a clean now and then .As with petrol ones . lpg can be problematic if not serviced reg . Quite difficult to get a lpg engineer who realy knows his nuts found a good one in Edinburgh bottom of Leith little back street garage but has all the kit and not expensive good luck
Post #484126 23rd Jul 2018 10:13am
Zambezi
Thanks Rik
I had the LPG serviced about 3,000 miles ago but I'm not confident that much was done as part of the service and I'm not returning to that particular LPG "Specialist".
Hopefully the place I'm booked into for next week will have a proper look and sort it.
Cheers
Zambezi silver
Post #484127 23rd Jul 2018 10:22am
dingg1
If you're getting consistant lean codes when on lpg you do have an issue and risk valve damage
Its NOT normal on a well set up system
Post #484128 23rd Jul 2018 10:24am
rik
60000 miles eml on and off still running like a watch BMW engine pretty bullet proof towed caravan for 100s of miles with light on no problem jag engine a bit softer in the valve seats
Post #484129 23rd Jul 2018 10:50am
rik
Check also for air lock in cooling system as vaporizer needs to be water heated to work and is first to suffer if air locked could be the reason why she switches to petrol
Post #484130 23rd Jul 2018 11:06am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
have a read here :
http://www.fullfatrr.com/forum/topic42510....turn+valve
just to add the fix i did is still working perfectly ! 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #484132 23rd Jul 2018 11:36am
