Home > Maintenance & Mods (L322) > Air Suspension Reservoir Replacement |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 |
Bouyed by my success (I hope - no obvious leaks) at changing the gearbox oil pan & filter + mechatronic sleeve, I'm now looking at swapping out my very rusty air reservoir. I have a nice shiny new one from Dan (thanks Dan). The workshop manual says:
I'm not sure I understand those instructions - perhaps it will be obvious when I have the connector in front of me? What's the simplest way to swap it out? In the PowerfulUK YouTube video they take out and re-use the whole brass fitting with the new O-ring. I don't want to start a job I can't finish. Am I over-complicating things? 2016 Skoda Octavia VRS Estate <gone>2009 FF Vogue TDV8 Buckingham Blue</gone> <gone>2015 BMW 520D SE (not my favourite car)</gone> <gone>2009 D3 HSE Galway Green</gone> |
21st Jul 2018 8:35am |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Recently replaced mine , not easy !I jacked up all four wheels off the ground from the fully raised height. There was no problem releasing the pipe leading to the contraption at the front , how ever that control unit mounts fell apart as I removed it to get at the mount bolts for the tank. Abit of a headache getting at the rear mount bolts as the plastic box had to be prised away to get them.
21st Jul 2018 10:05am |
Thanks both.
23rd Jul 2018 8:42am |
Ah ok , I did think yours might be different but didn’t check , sounds a lot simpler than the older model, so I look forward to my upgrade whenever that might be. |
23rd Jul 2018 11:29am |
