Home > In Car Electronics (L322) > iPhone function
Scottjp
iPhone function
Afternoon All,
I've got a 2012 Westminster and the iPhone used to work fine through the car, with last numbers dialled being displayed on the screen. But a couple of months ago I noticed that it no longer retains any numbers and only works if I type the phone number in each time. This would be ok if I could remember any numbers! Does anyone else have the same issue? Does the car need an update to match a phone update, I wonder?
Thanks in advance Thumbs Up
Post #483375 13th Jul 2018 2:12pm
MattC
United Kingdom 2011 Range Rover Vogue SE TDV8 Alaska White
Mine changed in the same way for no apparent reason, although i noted that once you have made a call once connected to the bluetooth the call history would be active. I ended up using the 'hey siri' function to make all calls- so much simpler and allows you to fully concentrate on the road.
Post #483378 13th Jul 2018 2:47pm
Scottjp
Thanks for the reply.
Mine doesn't recall numbers even once its been used. That's a good idea re: Siri to dial out but I do like to see who's calling me before answering!
I wondered if it was a software issue as my Brother-in-law had a similar issue with a Transit van and wondered if it was similar system.
Post #483380 13th Jul 2018 2:54pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Mine works fine - I just press call register on the screen and then press dialled calls, and all the calls I've made on the phone are all listed there, whether dialled through the car or not. Seems to also be available almost instantly when I start the car too. If thats not working, then its more likely a bluetooth setting on the phone rather than in the car. My iphone has the latest ios on it and not had a problem. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #483383 13th Jul 2018 5:03pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Have you tried deleting the phone from the system and re-pairing it? Cheers Ian
Kielder 4x4 Safari
Post #483387 13th Jul 2018 6:33pm
Scottjp
No, not tried that - i’ll give it a go Thumbs Up
Post #483404 13th Jul 2018 10:56pm
Scottjp
Mine used to do that, nicksaab!
Post #483405 13th Jul 2018 10:58pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I had the same until I found a new option on my phone. Try the following.
Settings
Bluetooth
Land Rover (click on the i to the right hand side)
Sync contacts - everything should then have a blue tick against it.
Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #483414 14th Jul 2018 7:07am
Scottjp
Thanks for the reply - I wasn’t aware of that so will give it a go! Thumbs Up
Post #483440 14th Jul 2018 2:29pm
Scottjp
Thanks chris_read, worked a treat - good old apple!
Post #483708 18th Jul 2018 12:23pm
chris_read
Post #483740 18th Jul 2018 6:01pm
