![]() | Home > Technical (L322) > RSD - Random Suspension Drop? SOLVED |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Also worth checking the reservoir underneath they do corrode and can leak |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
^.......and associated pipework. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I posted this a while back, and it's been mostly behaving. Until yesterday and came out of work to find the rear end sitting on the stops.
Haven't been under the car yet but found this in the workshop manual:
Might explain the random drop and how the sensor could be the culprit. It doesn't always drop (hence thread title!) but I want to know if it's a slow leak. I went to the car four times yesterday and measured the height and it was stable all day. But some days like earlier this week, it will be on the bumps. I think the Periodic Re-leveling coupled with a bad sensor/connection fits the symptoms. Also the code ^ does not say LH or RH which is weird. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Your screenshot says "rear right height sensor".... ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Ah Joe - thank you - I must be dyslexic I really didn't see that...
Hi Team,
Found it pretty much like this - the insulation /conduit kinda falling off, and the cables have been spliced sometime in the past. (sssuming the way it looks in the photo is not normal). I pulled the connector, which looked ok, no signs of corrosion so I hit it with some Contralube contact protection gel and plugged it back in. I'll see how it goes over the the next few days, but might have to re-do the joints. Geez it's a big tricky to reach in there, even with the wheel off. Reaching in, stripping and soldering doesn't look that easy... Any suggestions on best way to repair this very welcome as always. Cheers, Greg . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The valve is easily unclipped from its 3 pronged mounts then lowered although you might want to remove the liner for best access. I had mine out a week ago when swapping front and rear valve blocks tracking down the reason for the front lowering overnight.
Just a minor update; as above ^^ I re-plugged the connector with some contact get and lashed up the exposed wires and open conduit with electrical tape two weeks ago.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Greg, why not apply same treatment to remaining tree sensors. it won't hurt none. |
Definitely Nino, I already did the other side rear. I put this stuff on any connectors I remove, inside or out.
I use CorrosionX, first recommended by Haylands.
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Don't know if this is related but I am new to ffrr and coming from disco to ffrr but a lot of disco owners where getting gremlins in the electrics due to using car washes , the high pressure hoses wetting out and corroding connectors mine only got a blast after off roading , but having said that they are all Landrover and as we know they just do what they want and back Again for no reason . I am a big believer in undersealing and mine will be getting the full treatment once I know how she goes , for me it protects electrics and b/pipes etc from corrosion
@henda
