Home > Technical (L322) > Engine management light on
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Hi Guys
I have a TDV8 3.6 10 plate amber management lights on and its flashed up restricted performance a couple of times but goes away.
it idles rough sometimes but levels out no black smoke that I notice
so is it EGR valve ? its done 94000 miles.
Turbo actuator.
I had a mate use his code reader which said EGR fault but cant pinpoint.
any help would be good.
Thanks
Geo
Post #482093 28th Jun 2018 1:55pm
have you checked your turbo pipes? ... - .- -.
Post #482097 28th Jun 2018 2:26pm
Geo2toy
Hi Stan
cant see any splits but I did tighten them all and then tried clearing the codes but amber was still on.
went to get fuel and the restricted power came on again on route.
stopped put fuel in it (wife drives it so you know what im sayin)
after filling it up started it no lights at all thrashed it home no lights on so I don't know now.
#Wait and see what happens I suppose. Bow down
Standard FF fix if in doubt switch it off and back on again Rolling with laughter
Post #482101 28th Jun 2018 3:40pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Mine did this and a good dose of injector cleaner sorted it. I couldnt go 50 yds without it playing up and now it purrs again. Try and get hold of Forte brand or Sol-x. Local mechanic should have it. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #482117 28th Jun 2018 7:03pm
