Home > In Car Electronics (L322) > 2010my Fuses
Beemergriff
2010my Fuses
Does anybody know which fuses in the front fusebox (behind glovebox) are OFF when ignition is off Question
I have my dashcam connected via a piggy-back fuse, and have tried a few that would make sense to go off when the ignition is off, but so far it stays powered all the time.
If need be I will go through the elimination process and pass on my findings, but am hoping somebody has already done that Smile Andrew
Defender 300tdi
RR Classic Off-road Trialer
BMW X3 E83
BMW 330 E46 convertible
Post #482112 28th Jun 2018 5:38pm
have a look at the dash camer installs in the wiki, I'm sure theres one which connects to that fusebox... ... - .- -.
Post #482115 28th Jun 2018 6:56pm
Beemergriff
Thanks Stan. I will do that Andrew
Defender 300tdi
BMW X3 E83
Post #482116 28th Jun 2018 7:01pm
GraemeS
Australia
I wired a USB socket to the interior light power saving circuit inside the roof console. It stays alive for a while after the ignition is switched off which I thought could be worthwhile.
Post #482130 28th Jun 2018 9:42pm
kooky_guy
Isn't there a fuse for the cig lighter/power sockets in that box? All of mine go off when the ignition is off (after a short delay). I've got my dashcam plugged into one of those currently and intend to run it straight to the fuse at some point... 2010 4.4 TDV8 Vogue SE
Post #482152 29th Jun 2018 7:57am
