Home > In Car Electronics (L405) > Which tracker? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 |
The assumption of many insurers seems that trackers are all aftermarket fitments, so the LR tracker which is built in at the factory during normal build seems to be difficult for them. You should have Land Rover In Control Secure. You should be able to go on to the LR website, create a profile using your VIN and then download a certificate of installation. My insurers (Direct Line/Privilege) at first didn't accept that as it was not a certificate of installation (as not aftermarket), but once I explained that it was built in at the factory they did accept it. Whether that works with an online only comparison site is another question. Only Range Rovers since 1988 |
28th Jun 2018 1:11pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 |
My incontrol expires in November, my insurer reluctantly accepted it but wanted a 5 not a 6 (think that was it). Wondering whether to pay the ransom to LR or get an aftermarket fitted. letters not necessarily in the right order |
28th Jun 2018 6:37pm |
ICS is Thatcham 6, so if the insurers want 5 you presumably need to go aftermarket. Only Range Rovers since 1988 |
29th Jun 2018 11:27am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1448 |
Cat5 seems a bit excessive over and above a built in Cat6 system. Seems the main difference is the Police Level 1 Response (if you can believe that!!)
29th Jun 2018 2:42pm |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
Part of the problem is that I have heard that the std trackers location or at least how to disable it is well known amongst thieves . Cat 5 really is the only way to go as the instant the car moves without the engine being running or without the 2nd fob being inside the cat an alert is raised ! |
1st Jul 2018 2:55pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1242 |
I dare not say who I insured with for 400 quid. ( saga!!!!!!)
3rd Jul 2018 2:45pm |
