Home > Technical (L322) > rear brake calipers
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
rear brake calipers
ive just recieved from ebay a new pair of rear calipers for 2010 l322 which I intend to fit at the weekend together with new disks and pads. however, the calipers currently on the car are aluminium whereas these new ones are cast iron. anyone with experience of this or know the reason why some would be aluminium and some iron? do they fit ok etc?
these are branded NTY and the box clearly states
"Land Rover lll/lV 02 - Range Rover lll 02-12 - Range Rover Sport 05-13"
cheap enough at £75 a pair delivered & the reason I'm changing them is because the last time I bled the brakes about 3 years ago the rear caliper bleed screws were extremely tight and felt like they were about shear if i tried any harder to undo - they will likeley be worse now. I'm told that the cause of that tightness is steel bleed screws corroding in aluminium calipers?
Post #481531 21st Jun 2018 12:38pm
dexion7
so... job done, calipers identical to originals except no land rover logo and made of iron.
wheels off, replace disks, pads, calipers, flush new fluid through and then wheels back on, about 2 hours all in
Post #481570 21st Jun 2018 8:32pm
i wonder why the material is different.. ... - .- -.
Post #481574 21st Jun 2018 8:40pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Thread revival,,,, my 2011 VSE has a sticking drivers side rear caliper, tried to get one locally but no one had one , main dealer quoted 455 euro with a 2 day delivery and i need RR Saturday latest. I can courier one in from uk for sat am BUT i can get 2009 rear calipers in dublin and the difference apparently is 2009 is steel and 2011 is aluminium but but use same fittings , anyone with any experience or advice re the please. I did find one post in the search function and poster said he had no problems. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #505940 21st Feb 2019 7:13pm
