Home > Wheels & Tyres > seeking clarity on L405 21" on L322
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
I've read all the related threads before asking this - honest!
considering fitting this type of wheels my 2010 SE as i think the standard wheels dont fill the arches properly.
https://www.ebay.co.uk/itm/Genuine-L405-Ra...0005.m1851
posts in some threads on here say that the centre is a slightly different diameter and some say that the offset is different. another post says that the front wheel, on full lock, touches the inner wing.
would these wheels stick out maybe a couple of inches more and remedy the problem?
pictures of these wheels fitted on a 2010 would be great
Post #481428 20th Jun 2018 10:47am
Well.....if you'd read this thread - you'd have seen the photos Whistle
Post #481429 20th Jun 2018 10:53am
....and, i have these type on mine but with the black inserts,
speedo reads a little closer to actual speed..
Post #481430 20th Jun 2018 10:55am
dexion7
i have read that thread - all 13 pages! lots of nice wheel pics but can't find one that shows if the wheels fill the arches as i would wish i.e. a shot from behind the car.
in addition, still no clarity on the fitting issue: lots of folk saying "take the l322 wheel off and fit the l405 - it's simple" but on other threads there are comments that the central spigot size is very slightly different. if the spigot diameter for an l405 is larger than l322 then the wheel will go on ok and appear to tighten up ok too. howvever, under those conditions centralisation of the wheel on the hub would depend upon wheel nut clearance in the wheel's holes which would likley also be subject to whether you fully tighten them before or after you put the vehicle's weight on the wheel.
hence why i was seeking clarification of the spigit size as well as a rear view shot showing how well those wheels fill the arches.
Post #481445 20th Jun 2018 1:24pm
Tyres are slightly wider & taller than the standard L322's
The standard L405 20 is a 255/55/20 vs 255/50/20 on the L322
The 21's are the same height - so very slightly taller.
The 21's are 275 wide
First time I heard of the spigot difference.....
Post #481459 20th Jun 2018 2:53pm
the 21'' will stick out further as they are 9.5j as opposed to the standard 8.5j...and as alistair says the tyres are 275mm wide instead of 255mm .. ... - .- -.
Post #481460 20th Jun 2018 3:05pm
Spigot size is 72.6mm on both the 322 & 405 sir so 405 alloys fit EXACTLY the same on both vehicles Thumbs Up
Post #481463 20th Jun 2018 3:22pm
dexion7
many thanks for the answers guys
Post #481466 20th Jun 2018 3:46pm
Post #481499 20th Jun 2018 10:39pm
