Home > Maintenance & Mods (L322) > Wheel brace does not fit nuts
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
I decided I wanted to paint the callipers on the car yesterday, but when I tried to take the wheels off the 22mm wheel brace would not fit all of the wheel nuts, some fitted perfectly but at least half I could not get a 22mm socket or wheel brace on. I ended up having to by a small socket set from Halfords that had a 23mm socket included. Has any one else had a problem removing wheel nuts? Shocked
Post #480961 15th Jun 2018 12:03pm
Baltic Blue
Do a search “swollen nuts” , a very common problem.
Post #480963 15th Jun 2018 12:18pm
do the search here on the forum and not on google as you will get a different answer there.. Mr. Green ... - .- -.
Post #480966 15th Jun 2018 12:32pm
dingg1
you Sir
have swollen nuts , not a diagnosis anyone wants to hear but in reality not a big issue
it happens to us all in time Big Cry
Post #480967 15th Jun 2018 12:40pm
Baltic Blue
Stan
Rolling with laughter Rolling with laughter Thumbs Up
Post #480968 15th Jun 2018 12:42pm
yep, swollen nuts on mine, have changed them once, now resigned to the fact they take a 23mm socket not a 22, its a feature. There is nothing that can't be fixed with a hammer😜😜
Post #480981 15th Jun 2018 3:29pm
Baltic Blue
I solved the problem by buying a set of solid nuts off eBay and they have been brilliant.
The galvanised coating tarnished to exactly the same silver as the wheels.
Sadly they don’t seem available now?
Post #480983 15th Jun 2018 3:44pm
Cavalier
Thanks for the replies guys, 23mm socket seems to do the job Thumbs Up
Post #481047 16th Jun 2018 9:02am
