![]() | Home > Technical (L322) > new owner L322 what are best preventive task to carry out |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1404 ![]() ![]() ![]() |
Just on A it may need a new final stage resistor, a well known weakness. Only Range Rovers since 1988 |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I have a 2003 V8 and I’ve found the IIDtool to be indispensable, one thing to check would be the battery as these vehicles are very voltage sensitive and another, which is tied to the first, is to check the alternator output as they do sometimes give up the ghost.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Number one on my checklist is the radiator - the gearbox is cooled by the bottom 9 or so rows of fins on the radiator - if this gets sludged up (which they do) then the gearbox oil cooler also sludges up and prevents the gearbox cooling properly.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 529 ![]() ![]() ![]() |
IID would work on both but you would need an extra licence for the second vehicle for many of the features. A low cost alternative is the iCarsoft. It's nowhere near as capable (it can only read and clear faults) or easy to use but it's about a fifth of the price. 2016 Skoda Octavia VRS Estate
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
You will need an IIDTool. |
Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44 ![]() ![]() ![]() |
Brilliant info just what i needed the car has had a new rad and water pump, however i will defo remove and reverse flush, as i need to replace fan shroud due to a big crack in top corner covered with black duct tape (probably got damaged when the previous owner replaced water pump)
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1369 ![]() ![]() |
non compatible antifreeze been added IMO OAT added to non OAT or vice versa |
That could be the answer actually because when I drained it down it did have pink antifreeze in, and eurocarparts do sell pink oat antifreeze. ______________________________
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Timing chain and guides if not done already are prone to failure and I believe the LPG converted models fail earlier but that’s just my opinion. |
