Home > Technical (L322) > E G R PROBLEMS |
disco 3.5 Member Since: 14 Aug 2014 Location: barton seagrave Posts: 37 |
hi all, my engine management light has come on, took it took a local garage for diagnostic check and the code came up as e g r fault, have been advised to giv e the car a good long run because they believe the egr dont like me just doing short little runs all the time, the engine management light was off when i picked the car up so i head off to give it a good run. 5 minutes down the road descided to open her up a bit soon as i put my foot down the enginemanagement light came back on, the garage said if this happens i will have to replace both egr because they wont know which ones at fault, is this good advise, if it is how much am i looking at to replace them many thanks LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
13th Jun 2018 7:30pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
have a remap and blank the EGR and its cooler , you wont regret it and its probably cheaper to do too |
13th Jun 2018 8:43pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Try induction cleaner. I used Revive. It’s available in uk. Then remap to disable EGR. ______________________________
13th Jun 2018 8:47pm |
http://www.autosessive.com/blog/index.php/...-reviewed/
13th Jun 2018 8:51pm |
is remapping it legal. will it pass the new mot
13th Jun 2018 8:54pm |
take you caps off please pal , no remapping is not illegal and wont effect MOT |
13th Jun 2018 8:55pm |
cheers bembo 449 having it mapped out and blanked not affect the engine ? LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
13th Jun 2018 9:01pm |
well yes it will ,better performance , better economy and smoother running , there are no downsides if you do the full mod pal |
13th Jun 2018 9:04pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
If it's a 3.6 then your best option is to have the EGR's removed and blanked and then the car remapped to accommodate.
14th Jun 2018 7:58am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
MoT testers are not allowed to remove covers. As long as the top engine cover is on, there is no way to see if you have EGRs enabled or not.
14th Jun 2018 2:17pm |
