Home > Maintenance & Mods (L322) > Misfire in hot weather
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Folks,
4.4V8 petrol 04 plate (with LPG conversion)
I have a misfire that is intermittent, as far as I can tell it only happens when the car has sat out in the sun and is warm -- this misfire appears to correct itself as soon as it switches to LPG, any thoughts please?
Many Thanks
Post #480609 10th Jun 2018 5:32pm
dingg1
lpg usually shows any weaknesses in the ignition system so if the issue is only on petrol it suggests an issue with petrol delivery , maybe a petrol injector playing or gumming up , try running on petrol for a couple of days and see if the issue disappears
Post #480629 10th Jun 2018 8:03pm
Bushy30
Thanks Dingg,
Just been for a run, and it's very lumpy, i930 reports misfire on cyl 8 -- now I had bank 2 apart yesterday, well to the extent of checking and contact cleaning coils, oddly 5, 6, and 7 sprung nicely and needed the nuts to sit on top of the plug, 8 onthe other had sat down and stayed down, noe whilst the spring looked good I was running out of time and couldn't see the top of the plug -- I was only there checking for oil ingress etc.
To be fair it could be missing on LPG too, I suspect the LPG interrupt system maybe fooling the engine ecu that it is firing correctly.
All other thoughts welcome
Post #480633 10th Jun 2018 8:09pm
Bushy30
news.......... ran with no misfire today, very curious, still hay to listen to suggestions
Post #480733 12th Jun 2018 1:13am
Bushy30
Update: -
the problem only appears on bank 2, cyl 5. 6. 7. or 8
From start up in hot weather it misfires, faults are stored, as soon as it switches to LPG no faults stored, now I suspect the LPG electronics is fooling the systems.
Any thoughts please?
Post #481583 22nd Jun 2018 12:17am
Bushy30
Further update -- changed the hoses on the PCV -- touch wood, seems ok!
Post #482690 5th Jul 2018 2:53pm
