![]() | Home > Technical (L322) > Key fob stopped working |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I have a similar issue I now have one that does everything one that opens doors and starts but no fob and one key that just opens the doors - I have tried local specialist has tried all that happens is the the keys change operation but only one will work on the fob at any time Good luck hope yours is an easier fix |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
When you synch the second key you must not put it in the ignition as that starts the cycle over again. Apologies if you were aware. |
Keep trying, took me several goes to get it to work:
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I didn't sych a second key, as the other key works, I just was trying to sych the one the stopped working. |
Update: I managed to get the working key into sych mode with the procedures listed but the second key will not sych. |
