[SOLD] L322 Range Rover HSE 2002 TD6 | |
Please note, offer made at price above that listed here, so currently "SOLD"
£2550 ovno
On offer at this specification and advertised elsewhere. Car must go (so says SWMBO!!)
- High specification HSE inc. Bordmonitor screen, SatNav etc. (but no sunroof)
- Alveston Red - the best colour for an FFRR !!
- First registered April 30th 2002
- I am the 7th owner, but have had the car for the last 10 years, since July 2008, purchase mileage 86,782.
The engine just goes on and on, has never missed a beat, and has always started
first time, has been my daily driver and has never left me stranded. Has been the
best car I have ever owned, ...for so many reasons.
- All driving, gives 26 miles to the gallon
- 184,000 miles on the clock
- REG: EA02 FMM (was B3 TJC)
- Engine Number: 25105016710937
- Will come with new MOT
Build Sheet PDF
Features: ( + (plus) means added feature)
- Sidesteps (just replaced with "newer ones")
- Front and Rear mudflaps +
- Xenon headlamps
- LED front sidelights +
- DRL foglight conversion +
- RSE (screens not currently wired up) +
- Reversing Camera (not currently wired up) +
- Rear DRLs in reflectors (LEDs on the way out!)
- Factory towbar mounting and wiring - twin sockets
- Colour coded grille and side vents + (originals in grey available...)
- Colour coded mirror covers +
- "Range Rover" black badges to front and rear of car
- New Aero style wipers (fitted May 2018) +
- Rain Sensor
- Puddle lights
- Wide angle mirrors + (removes blind spot found on original mirrors)
- Front towing eye cover +
- EAS works as it should (set 10mm higher at the rear)
- Engine tuning module fitted +
- EGR blanking kit fitted +
- Later style 5 spoke wheels with General Grabber AT2 (plenty of tread 5/6mm minimum) "New" Goodyear on spare - will be same style
- Green Oval Landrover wheel centres
- Park Distance Control - front and rear
More Features: ( + (plus) means added feature)
- Factory SatNav - original DVD
- Upgraded BM54 Radio to include AUX IN +
- Harmon/Kardmon sound system
- 6 CD changer in glovebox
- Interior footwell comfort lights
- Sand leather interior - excellent condition for age
- Cherry wood
- Colour coded interior over carpets
- Colour coded steering wheel cover +
- "Range Rover" black decals to steering wheel and door air bag covers
- Heated front seats
- TV in Motion cable +
- Tinted rear windows
- Auto dimming rear view mirror
- Air conditioning works as it should
- Factory wired for phone/voice control, 54pin plug rewired for bluetooth
Work Done:
2010 01 092135 New LR replaced and fitted Automatic Gearbox
2010 01 092135 New Rear Wiper Assembly inc. Motor
2010 03 106505 New Steering Control Arm
2010 07 108500 Front Brake Discs
2011 07 000000 New Air Con Condenser
2011 07 119933 New Steering Control Arm
2011 08 120764 Gear Selector Lever
2011 10 000000 Front Suspension Airbags and Struts (Delphi)
2011 11 000000 Engine Thermostat
2012 04 000000 Rear Brake Discs
2013 04 000000 All Rear Suspension Bushes, inc. inners and Toe Links replaced (JLR)
2013 04 137100 Front ARB Drop Links
2013 09 000000 Coolant Tank
2013 09 000000 EGR Thermal Valve
2013 09 000000 New Radiator
2013 10 000000 All Rear Subframe Bushes replaced (JLR)
2014 03 000000 3 new Glow Plugs
2014 05 000000 2 new Diesel Injectors
2014 06 150100 All Brake Pipes and Hoses replaced (JLR Rear Flexis)
2014 07 000000 New Air Con Condenser
2014 10 000000 EAS Compressor
2016 10 000000 Drive Belts x 2
2016 10 000000 Engine Thermostat
2016 10 000000 Water Pump
2017 03 000000 Rear Height Sensor
2017 06 000000 LH Toe Link Bracket welded for MOT
2018 03 000000 LH rear wishbone replaced with refurbished one
2018 03 181330 New Battery Varta L1
Many other small parts fitted as and when required, receipts may be available
Service History:
2003 04 012260 Oil Service Inspection 1 Inspection 2
2004 01 025023 Oil Service Inspection 1
2004 07 036338 Oil Service Inspection 1 Inspection 2
2005 11 051266 Oil Service Inspection 1 Inspection 2
????? Oops !!
2008 07 086782 Oil Service Inspection 1 Inspection 2
2009 01 092135 Engine Oil and filter change
2010 03 106505 Air Filter
2010 03 106505 Engine Oil and filter change
2010 03 106505 Pollen Filter
2010 04 107307 Oil Recirculation Filter
2010 07 108500 Front Brake Pads
2011 08 000000 Fuel Filter
2011 08 120764 Air Filter
2011 08 120764 Engine Oil and filter change
2011 08 120764 Pollen Filter
2011 09 000000 Transfer Box Oil Change
2011 11 000000 Gearbox Oil change (5 litres)
2012 04 000000 Rear Brake Pads
2012 04 000000 Rear brake Shoes (handbrake)
2012 08 129610 Engine Oil and filter change
2013 06 000000 4 Wheel Alignment
2013 07 139390 Air Filter
2013 07 139390 Engine Oil and filter change
2013 07 139390 Pollen Filter
2014 02 146970 Engine Oil and filter change
2014 06 150100 Front and Rear Diff Oils
2015 03 157329 Engine Oil and filter change
2015 03 157329 Gearbox Oil and Filter (JLR) change (5 litres)
2016 03 166635 Engine Oil and filter change
2016 06 169000 Front Brake Pads
2017 01 173665 Engine Oil and filter change
2017 06 169000 Front Brake Pads inc. Wear Sensor
2017 10 000000 Rear Brake Pads
2018 03 181330 Air Filter
2018 03 181330 Engine Oil and filter change
2018 03 181330 Fuel Filter
2018 03 181330 Gearbox Oil change (5 litres)
The Not So Good Section:
- Low Range...you can go to low range, but you can't get back to high range !!
(Despite my best efforts and with help from RRPhil, unable to resolve. Everything "works" just not this!)
Regardless, car has still gone wherever I have pointed it, mud, snow, sand, gravel. To be fair, 99.5% on road.
But unless you want to really become a tractor, don't touch that button!
- "Folding" mirrors, let's just call them mirrors!
- LH rear quarter panel has some rust, (and a not so good bodywork repair done by me!)
- Heated windscreen - only a couple of bars work now, also a couple of stone chips, but not affecting MOT area
- High level brake light reflector/cover missing in action after the big freeze in 2018 - still works OK though
- Fuel Burning Heater - not working - believed to be the fuel pump in the rear axle
- It is a 16 year old car so the bodywork has suffered a fair few stone chips and other age related marks,
nevertheless still a fine looking beast and the paintwork still holds a good shine
Additionals:
- Car will come with drop plate towbar, ball and blanking grommet
- Car will come with custom "FFRR" lettering (where the HSE should be) and a fullfatrr.com sticker in tailgate window
- Currently viscous fan and shroud not fitted (just not needed!) but will come with car
- New replacement key planned as rubber button falling out - manual lock still works fine
- On/Off Power and momentary switch fitted from front to back for car PC powerup
Benefits:
- Used on a daily basis for a 25 mile commute
- Routinely serviced and maintained by enthusiatic owner
- All the FFRR issues seem to have been ironed out
- No more rusty brake pipes (apart from rear flexis!)
- Now just about run in!
- Did I say the best colour for a FFRR!
- Not as complicated or difficult to maintain as the newer models
- Warts and all can be found on the forum / gallery
- You won't find a better value L322
- You can't believe it can you, all that for just £2550 !!
Available for viewing and quick sale evenings and weekends. Please initially contact me via PM on the forum. Will not be offended by starting offers .
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember
