Home > Technical (L322) > Brake pedal preventing start
ST12AT
Hi everyone,
Recently had a warning come up on the dash saying low brake fluid. I got home and topped up with some fresh fluid. Upon attempting to restart the vehicle - nothing. The dash displays the ‘press brake when starting’ even when the pedal is fully to the floor. The pedal also gets 90% down and then clicks/knocks before being fully depressed.
I’ve had a look to see if the brake pedal switch had somehow got disconnected but all seems ok (even though I’m not sure how a piece of plastic senses the pedal moving?)
It’s a 2012 Westminster
Battery shows 11.6 volts
Thanks.
Post #480418 8th Jun 2018 11:38am
ST12AT
****UPDATE****
So, I’ve spent hours trawling the internet to see if there have been similar reports and the closest I came was a guy in America and he solved the problem by stamping hard on the brake pedal - voila!
Started first time but I’m stuck with a very long travel on the pedal and hardly any braking power at all....
Post #480425 8th Jun 2018 12:50pm
sounds like the brakes need bleeding to get rid of an air lock.. ... - .- -.
Post #480426 8th Jun 2018 12:53pm
ST12AT
Front passenger wheel arch...
Post #480430 8th Jun 2018 1:08pm
