Home > Technical (L322) > Engine Management light and hissing sound, 4.2 S/C |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 302 |
I found an hour today, so managed to get three out standing jobs done on the fleet. 116i Has been giving an intermittent vanos solenoid fault for a while. Fix appears to be remove, clean and refit solenoids with new O rings - managed to get that done. 40 minutes. Including dropping a T20 into the abyss and having to remove some of the undertray to retrieve that little swine. On a roll I jumped under the bonnet of the 330ci and changed a power steering cap seal to stop it weeping on track. (30 seconds)
14th Oct 2017 3:24pm |
Simgoy Member Since: 13 Oct 2017 Location: Swindon Posts: 3 |
Did you cure this? Or do you still have error codes |
18th Oct 2017 5:22pm |
Sorry for late reply, the short answer is yes, shes cured and back to her old self.
22nd Oct 2017 9:22pm |
Shauny0809 Member Since: 31 May 2018 Location: Wigan Posts: 1 |
Hi I’ve got 2005 Range Rover sport 4.2v8sc and it’s got hissing sound coming from drivers side and missfireing with reduced proformance and won’t go over 3k revs or if u put your foot down to much it looses power and same on hillclines I’m sure it’s the same car as this happens when it went for mot |
1st Jun 2018 8:09am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
if you have a sport then you are on the wrong forum, try here,
1st Jun 2018 8:14am |
Sorry just remembered about this, whilst a sport its the same engine so I'll try and reply to be helpful!
5th Jun 2018 5:54pm |
