Home > Technical (L322) > Air suspension on 2011 vse |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
5th Jun 2018 10:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35373 |
just a guess but is the the air compressor exhaust filter ok..maybe it needs a drill hole in it.. ... - .- -.
6th Jun 2018 7:04am |
Thanks Stan , i will have a look later 2015 4.4 AB
6th Jun 2018 7:49am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
I can only talk from D3 experience but the pressure dropping like that is normal. Once the reservoir is filled the pressure on my D3 would drop from 260Psi to 20Psi. This is due (I believe) to the reservoir valve closing to isolate the reservoir and the compressor then exhausts the excess pressure. There can also be an issue that the exhaust cycle doesn't drop the pressure sufficiently so you get a C1A13 - Pressure does not decrease when venting gallery.
6th Jun 2018 9:50am |
Thanks Mike , i will try that and see what the live values say. 2015 4.4 AB
6th Jun 2018 4:14pm |
