![]() | Home > Technical (L322) > 2004 L322 TD6 white smoke problem |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
White Smoke = unburnt fuel....
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I would do I leak down test on the injectors first, it’s a quick and cheap job (£20) that you can do yourself and it will identify any injectors that are knackered and putting out too much fuel. I don’t have the td6 manual but I assume that the figures required for the injectors and their ideal operating parameters will be in there.
GSM Member Since: 15 Feb 2011 Location: Central Posts: 6 ![]() ![]() ![]() |
Thanks both for your replies. Some interesting reading at the link supplied. I was speaking to someone today who said it could be fuel related too.
Update. I had to cut off the squidgy intercooler hoses and as soon as I removed the knife oil poured out, both sides. I have fitted a new intercooler. Next was to check the turbo - glad I did as it was knackered. Picked up a recon turbo yesterday and will fit it this week. I also took the opportunity to have the injectors tested while they were out - thankfully all 6 are fine. EGR blanking kit has been fitted and silicon hoses will be getting fitted. Fingers crossed for a smooth rebuild and smooth smoke free running. |
So another wee update. The turbo was fitted and the manifolds put back on. I started the old girl up and she ran sweet as a nut.....until my eldest (who was standing at the back of the car) proclaims there was oil drpping from the exhaust |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
For the exhaust you should have waited till it was dark then give it a good blast, just ignore the flames and sparks they calm down after a while. |
