Home > Technical (L322) > L322 TDV8 MOT/CONTROLE TECHNIQUE EMISSIONS TEST |
Nespouls Member Since: 06 May 2017 Location: Terrasson Posts: 24 |
I am becoming concerned at the increasingly tight limits on diesel emissions as European governments attempt to force older, “more polluting” diesels off the road. I know the UK MOT test specs have recently been tightened and here in France the Contrôle Technique was similarly changed on 22 May.
28th May 2018 4:08pm |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
Whilst I haven’t got an answer to your question, the French weekly motoring magazine AutoPlus regularly runs articles on the current state of play as regards diesels in France and what it means for the motorist. (I’m sure other motoring mags also follow the developing situation.)
28th May 2018 6:10pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As it is the result of an European Directive the ct requirements are the same as for the MOT. Depending on your French, if you do a search on "changements de controle technique" you will get a number of hits with the information.
30th May 2018 11:52am |
Bonjour Bébéchoon and Weegie,
30th May 2018 3:46pm |
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 |
I have just had my MOT on my 3.6 tdv8 and no problems with the new emissions test limits. It did however fail on a front wishbone...and that was only fitted in November last year so that is being fixed under warranty.
31st May 2018 1:02pm |
Thanks Tooltime, that’s very reassuring!
31st May 2018 3:25pm |
