Home > General > Advice required BMW 4.4 - Urgent
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Evening all !!
After the demise of my TD6 I am now looking to petrol. Can you give me any major indicators for the BMW 4.4 as I am seeing one tomorrow. Its done 120,000, full LR history allegedly. I am only interested in what to look for with the engine as fully versed in the rest of the car, any help greatly appreciated,
Have done a search and wiki but looking for instant help Rolling with laughter
I thank you Thumbs Up
Post #479613 29th May 2018 6:04pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Rattling from the front indicating the timing chain guides... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #479622 29th May 2018 7:26pm
Never had any issues at all with the engine on mine (from 60k to 120k) however from the bits you say you are familiar with expect:
Final Stage Resister - should have been replaced by now
Front driveshafts replaced on recall
Radiator clogged at bottom end
Gearbox "sealed for life" so wont get touched by LR but needed an oil change at least 40k ago. Probably fubarred by now.
All kinds of electrical/electronic gremlins Mike - MPx
Post #479626 29th May 2018 7:39pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Specifically on the engine (over 6 years of owning one):
1. Collapsed/destroyed crankcase breather pipes on top of engine - search is your friend here.
2. Small heater hoses at the back of the engine need to be checked - if they go you obviously lose all the coolant rapidly
3. Clogged radiator - causes various problems/symptoms
4. Continuous rattling is timing chain guides etc. Rattle on startup for a second or two is hydraulic tappets/vanos - annoying but as long as it goes away shortly after startup no problem.
5. Valve cover gaskets
Other than that, pretty reliable. Ours got sold at 150000 miles with no problems (having done all of the above over the 6 years we had it).
Post #479627 29th May 2018 7:50pm
stu1
And one more, check all coolant hoses - they could be quite brittle due to the elevated temperature the engine runs at.
If any look old/brittle/discoloured, replace them else you may live to regret it (probably at the most inopportune moment when the top hose lets go).
Post #479629 29th May 2018 8:04pm
Rosco
Thanks chaps, appreciated Thumbs Up
Post #479666 30th May 2018 7:30am
Elduke
Scotland 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I've sent you a PM Thumbs Up
Post #479667 30th May 2018 7:53am
