Home > Technical (L322) > 2010 Autobiography, tow tongue fitment?
Page 3 of 3 <123
p38arover
Australia
You took the pic with a phone? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #479400 26th May 2018 10:34am
Grizzly_Adams
Australia 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Yup Ron, I even tried rotating it on my PC and when I uploaded the picture it rotated back.. [/quote]
Post #479404 26th May 2018 12:03pm
pic sorted for you Thumbs Up ... - .- -.
Post #479406 26th May 2018 12:48pm
Grizzly_Adams
Thank you! Cool Bow down
Post #479407 26th May 2018 1:32pm
Grizzly,
What you have is a 2010 AB car with a JLR Design pack bodykit fitted. The rear piece of your bumper (the hacked up bit) should be removed to access the tow bar! The previous owner has obviously modified the panel to use the tow bar without removing this panel every time...
Here is a pic of one of my old cars with the same bumper kit fitted...
Post #479444 26th May 2018 10:19pm
You simply turn the 4 tabs 90 degree's and pull off that panel, when removed you will see the bracket your electrics socket should be fitted to on the left side of the tow bar bracket...
Post #479445 26th May 2018 10:21pm
Grizzly_Adams
Cam-Tech-Craig wrote:
Grizzly,
Thanks Craig - I had recognised the Design pack bodykit but didn't realise it needed to come off before accessing the tow hitch... so not only has this previous owner not known/bothered to do this but they have also moved the electric socket on to the design pack so it can't be easily removed anymore. Big Cry
Oh well, guess there's a little bit of re-wiring to be done before I can properly prove it works. Censored
I've seen some of your posts and work, very impressive Very Happy Thumbs Up
Thank you again very very much for the heads up Bow down Bow down Bow down
To save me searching around, do you know roughly here the 4 tabs are you speak of? Whistle
Post #479447 26th May 2018 10:59pm
Grizzly_Adams
ok, found the tabs.. pretty obvious when you get under the vehicle and look really.
I've only got 3 tabs because they've screwed the electric plug mounting plate in where the 4th tab insert would be (middle-drivers side)... I'm going to take off the the underbumper bit and see if I can see where the electric plug should be mounted.
Sheesh, some people.. what a hack job Big Cry
Post #479453 27th May 2018 2:53am
Grizzly_Adams
ok got some more photo's now I've taken that underbumper bit off (thanks Craig!)
The wiring hack (best way I can describe it):
If you look closely they've also hacked up some of the plastic at the back.. either that, or it's melted with heat at some stage:
But at least the tow tongue fits!
Though it does seem rather tight, does that top inset come out at all or is it supposed to be like that?
Thanks!
Post #479454 27th May 2018 3:17am
Grizzly_Adams
*sigh*
I think I've found the one bit of the tow hitch that they did get the grinder out for...
That tiny little bit that they've sheared off there is where it looks like you normally secure your trailer electrical socket - judging from photos such as this from roverparts.com
Can someone confirm please? Big Cry
Post #479455 27th May 2018 3:38am
The centre panel of the bumper also pulls off once you undo the two fixing plastic screw in thingy's!
I used to take mine off when towing as the trailer gets VERY close to the paintwork when hitching up!
Yes the tow electrics mount has been hacked off of yours by the looks of it! Rolling Eyes
Post #479487 27th May 2018 5:54pm
Drew
Australia 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Are there multiple tow hitch assemblies for the different regions? (Eg. UK, US, OZ)
@rar110 I’m also in Brisbane and have a 2007 L322 4.2SC but struggling to understand tongue weight limits. I am wondering if there are different assemblies for each market (even though they all look the same) then this may help explain things.
Not directly related to this thread I know... but indirectly may help me.
Post #587266 13th Mar 2021 9:12am
Grizzly_Adams
@Drew you're better off starting a new threat, your question will be lost in this one.
Post #587638 16th Mar 2021 6:42am
Grizzly_Adams
You're better off starting a new threat, your question will get lost in this one Thumbs Up
Post #587639 16th Mar 2021 6:43am
Drew
Thanks @Grizzly_Adams... will try and figure out how to do that Thumbs Up
Post #587664 16th Mar 2021 2:39pm
Page 3 of 3 <123
